Steering groaning (cold start)
Old Sep 17, 2011 | 02:25 AM
CPTAFW163's Avatar
CPTAFW163
Default Steering groaning (cold start)
Alright, I have been here a while and never really encountered this. When i start the truck up, I hear a groaning sound then it does down. Then if I start to turn the steering wheel, there is a groaning.
It doesn't do this when my truck gets rolling for a few minutes.
NOTE: I hardly drive my truck since the weather is nice, I ride my HD. So this truck gets driven once or twice per week (only 54K miles).
I have an extended warranty, should i just bring it in? I would like to know what it could be. Because i would hate to have it diagnosed then come to find out that it "is not broke enough" for warranty work. ALso, diagnosis is the only thing i need to pay for.
NOTE 2: I had the power steering pump replaced 5K miles ago (Look at how shiny it is in the sig).
I am thinking this might be more of a "get out and drive her more" type of thing.
Old Sep 17, 2011 | 06:21 AM
Novarider's Avatar
Novarider
Did you check the power steering fluid level? Usually ps groaning is caused by low fluid
Old Sep 17, 2011 | 08:20 AM
dhvaughan's Avatar
dhvaughan
get a cheap turkey baster from walmart and one or two quarts of power steering fluid. suck the old fluid out of the reservoir and replace. note the old fluid's condition - clean, moderately dirty, nasty? drive it around the block. repeat 2 or 3 times until clean the fluid remains pretty clean.
Old Sep 17, 2011 | 09:42 AM
CPTAFW163's Avatar
CPTAFW163
Ok I will check the fluid. But Since the pump was replaced 5K ago, I would have thought that it was not necessary. However, that was a year ago.
Old Sep 17, 2011 | 09:49 AM
CPTAFW163's Avatar
CPTAFW163
ok, checked it:
Level: About 1/8 inch below the fill line
Condition: Brand new, clear amber.
I am doubtful that the fluid being a hair low is causing the problems, but I will go out and buy some more anyway.
has anyone ever heard of the pulley failing on a power steering pump? And how do you know the box is done.
Old Sep 17, 2011 | 10:13 AM
If your power steering works the way you think it should (noise aside), then the pump is probably just fine.
Can you post a video so we can hear what its doing?
Old Sep 17, 2011 | 01:23 PM
CPTAFW163's Avatar
CPTAFW163
It is not very loud. Just sounds like the pump is working hard by means of more resistance at the pulley. I probably should have mentioned that the sound only happens when turning the wheel with the truck not moving.
Is it common for a power steering pump pulley to bind?
ALthough, maybe this is just NORMAL sounds from the power steering. Our rams really conduct engine compartment noise better than newer cars do. Maybe I am just paranoid. The steering is very good, no resistance or binding, very smooth. it is just a sound issue.
I am probably just being paranoid.
Old Sep 17, 2011 | 01:53 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You are right. My 98 did that, and so does the 2000. If anything, it's the gear box getting worn.
Old Sep 17, 2011 | 01:54 PM
I think so Cpt..... When you are turning while stopped, there IS a lot of stress on the pump, so, prolly what you are hearing is high pressure fluid going thru the flow control valve. Pretty normal. (just get a louder exhaust...... )
Old Sep 17, 2011 | 02:15 PM
zman17's Avatar
zman17
And just out of curiosity, what fluid are you using? Some people run ATF +4 in them.
