Sway Bar Bushing Set for 98 Ram 1500 2wd
Old Sep 17, 2011 | 01:03 PM
af78954's Avatar
af78954
Default Sway Bar Bushing Set for 98 Ram 1500 2wd
I'm looking to buy a set of polyurethane bushings to replace on my sway bar..I've seen 2 different sizes to choose from: 30mm & 32mm..Does anyone know how to determine what size I need for my 98 1500 2wd 5.2l before I order them?
Thanks for your time!
Old Sep 17, 2011 | 01:08 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Measure the bar with a cheap pair of plastic calipers.
Old Sep 17, 2011 | 01:23 PM
af78954's Avatar
af78954
Should my local autoparts have it?
Old Sep 17, 2011 | 01:55 PM
Doubt it. Unless they carry some odd stuff. Wouldn't hurt to ask though.
Old Sep 17, 2011 | 02:03 PM
af78954's Avatar
af78954
any idea where I can buy one?
Old Sep 17, 2011 | 02:10 PM
zman17's Avatar
zman17
Call and ask, even a cheap metal dial caliper is only like 20 bucks. And they can be very handy at times.
Old Sep 17, 2011 | 02:11 PM
zman17's Avatar
zman17
http://www.autozone.com/autozone/acc...mString=search
Old Sep 17, 2011 | 06:05 PM
seabass202's Avatar
seabass202
here is what I did, no need to buy anything. I took the side panel from a cardboard 12 pack soda case. I used a ruler with a metric side and carefully cut a notch out of it (cardboard) about 1.5 inches deep and exactly 30mm wide. then tried to slip it over the swaybar. it wouldn't go so I concluded I have the 32mm bar.
Old Sep 20, 2011 | 01:35 PM
af78954's Avatar
af78954
Thanks for your advise Seabass..I used a 3X5 index card & measured 2 slots on it-one with 30mm & the other w 32mm wide..Then I carefully cut them 1.5" deep..I went out to my truck & tried them both..The 30mm was too tight & bent the card but the 32mm was just right..It saved me a few $'s..
Old Oct 8, 2011 | 12:44 PM
faheyd's Avatar
faheyd
This was a great idea about the measuring first (I got the wrong set after taking a 'guess'). My 96 4x4/1500/ram/5.9 turned out to have 30mm. Apparently nothing on my truck is what it seems. Shouldn't I have at least the 32mm being it's a 4x4?
