Steering Stabilizers
Old Sep 17, 2011 | 05:11 PM
mikentiff's Avatar
mikentiff
Default Steering Stabilizers
What is the diff between the single and dual stabilizers for our trucks and what are the best ones for our trucks ?
Old Sep 17, 2011 | 05:46 PM
Single or Dual designate how many shock absorbers there are. (which is basically all they are anyway..... with equal damping on compression, and rebound)
What kind of driving do you do? Lotta trails? BIG tires? For most folks, a single is all you really need, if you answered 'yes' to either/both of those questions, go for the dual.
Old Sep 18, 2011 | 09:09 AM
mikentiff's Avatar
mikentiff
I'm gonna be running 35's but I have heard that a dual stabilizer will tighten up your steering ?
Old Sep 18, 2011 | 10:14 AM
beefythedodge's Avatar
beefythedodge
for 35s you will not need dual stabilizers. duals make it manageable when you are running not just taller, but wider like a 13.5 on up. The increase size of the contact patch really can cause the truck to be a bit more difficult to keep going straight, the dual stabilizers make the steering stiffer so it will not react as much to imperfections in the road.
it will def make the steering much tighter, i know a guy who runs 46s, and he runs quad stabilizers, and you cant turn it unless the meats are turnin. That is where hydro comes in handy.
you should be fine with one, but you will certainly get some comfort out of 2.
Old Sep 18, 2011 | 11:57 AM
mikentiff's Avatar
mikentiff
So having 2 will make my steering feel the way it would from factory not loose from side to side ?
Old Sep 19, 2011 | 09:51 AM
kadetklapp's Avatar
kadetklapp
Sounds like you need to tighten up the steering box.
Old Sep 19, 2011 | 10:00 AM
Need to eliminate all the slop before a steering stabilizer is going to help much.
Old Sep 19, 2011 | 07:35 PM
mikentiff's Avatar
mikentiff
Everything in the front has been checked and replaced what needed and the track bar and steering box have been replaced
Old Sep 19, 2011 | 07:39 PM
When was the last time you had an alignment, Do you have the 35's on there yet?
CPTAFW163's Avatar
CPTAFW163
Stabilizer will not take away steering slop.
