Help!! No brake, hazards, or turn lights in back only
I have a fast blinking sound when i use my signal lights. when i checked to see what lights were out, i discovered that my brake, turn, hazards, and cab brake light all out. My tail lights work and all the above work in the front. I checked the fuses and none of them look blown. I don't understand why the front blinker and hazards work but not the back. Do anyone have an idea what this could be.
Might have a couple problems there. Third eye runs right off the brake switch, the rest all go thru the multifunction switch (turnsignal switch on the column). If you have tilt wheel, might be as simple as some wires pulled, take the covers off the steering column, and have a look.
Welcome to DF!
Welcome to DF!
