Crap!!!
Old Sep 21, 2011 | 04:13 PM
offroadjosh's Avatar
offroadjosh
Default Crap!!!
Went to replace the steering stablizer and i cant get it off. Got the bolt and nut off on the pass side, and the nut off the driver side, but no matter how hard i pound on it it refuses to come out. Need help fast as i work tonight=/
Old Sep 21, 2011 | 04:59 PM
jasonw's Avatar
jasonw
Site Moderator
Knocker Loose (or some other penetrant, not WD40) repeatedly, soak it big time. Let it sit for at least 15 minutes with the stuff on it, let is soak in. Tap it with a hammer. Get it hot for several minutes or more using a small propane torch or equivalent. Tap it with a hammer. More penetrant. Repeat if necessary.
If that fails, there is always the grinding/cutting method. I had to do that for one of my wife's end links on her 2006 Durango... the lower bolt broke a socket wrench and an adapter trying to turn the nut. No amount of heat + penetrant would break her loose. The penetrant worked great on the other side, just not the passenger side. Had to borrow the neighbor's tools and cut it off.
Old Sep 21, 2011 | 05:28 PM
CPTAFW163's Avatar
CPTAFW163
you need a puller to pop it off. I was doing it and it felt like the bolt was going to break on the puller, then it finally popped. It really takes A LOT of pressure to pop it off.
But you need a puller. I used a 2 jaw pittman arm puller for it.
Old Sep 21, 2011 | 05:59 PM
Wombat Ranger's Avatar
Wombat Ranger
I smacked mine around for quite a while with no luck until i noticed that on the backside there is a place where you can put a wrench. I cant remember the size but i stuck it on and started crankin and it popped right out.
Old Sep 21, 2011 | 07:33 PM
offroadjosh
tried using a wrench. I guess i will try some form of a puller to pop it off. Thanks guys! Picked up a ranch 5000 stabilizer=)
Old Sep 21, 2011 | 08:27 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Josh? whats up with the thread title ? LOL Come on now, you been here long enough to know(about that) and do a search. Anyway(maybe this very recent thread will help), . https://dodgeforum.com/forum/2nd-gen...-bolt-out.html
Old Sep 21, 2011 | 10:46 PM
offroadjosh
tried search and for some reason musta missed that one! Will try again tmrw. Hoping it comes off. I hit it with a mixture of ATF and acetone...(btw slightly flammable...)
Old Sep 21, 2011 | 11:49 PM
gdstock's Avatar
gdstock
SLIGHTLY flammable? lol
Well, somebody did say something about putting some heat on it...
Old Sep 22, 2011 | 11:02 AM
offroadjosh
Lol minor fire... Nothing melted. Funny part was as soon as i got it out we got toned out for a fire :P
Old Sep 22, 2011 | 11:46 AM
gdstock's Avatar
gdstock
My yougest son, a vol ff, just got licensed this summer for pyro. scares me a little..........
