autopage remote start on 99 1500 ram
Old Sep 21, 2011 | 09:07 PM
trae08's Avatar
trae08
Default autopage remote start on 99 1500 ram
I bought an autopage c3-rs-603 a few short days ago. And i have most of it wired up. but the last part thats slowing me down is the 10 pin wire harness. Im not sure where to hook some of these wires up at.
Specifically, pretty much all of them.
im pretty sure i dont need to use a few of them but the others im not sure about.
and it says to connect the tach signal wire to the negative side of the coil if my vehicle has conventional coils. And where is the coil located?
Old Sep 21, 2011 | 09:17 PM
What engine ya got in your truck? If you have v-6, or v-8, coil is passenger side, front of engine. Right by the serpentine belt tensioner.
Old Sep 21, 2011 | 09:25 PM
trae08's Avatar
trae08
oh sorry it is a v-8.
Also here is the installation manual for the remote starter.
H3 – 8 White Connector Harness thats the one i have problems with.
Old Sep 21, 2011 | 09:31 PM
Add all of your truck info to your sig. Makes answering questions much easier. (and you don't have to type it out every time.)
Yep. One coil, passenger side front, right by the tensioner. Only one electrical connector, with two wires, one of which is ground. (black wire with grey trace.) (and of course, the wire to the dist cap, but, you don't wanna hook nothin' to that one.....)
Old Sep 21, 2011 | 10:05 PM
trae08's Avatar
trae08
Alright thanks. I will try it out tomorrow and see if i can get it to work. Ill post my results.
Old Sep 22, 2011 | 02:54 PM
trae08's Avatar
trae08
Alright i got it all hooked up and got it working today. The last thing i am having problems with is the door locks.
specifically this
H6 – 3 Pin Door Lock Harness
http://www.autopageusa.com/resources...MANUAL7908.pdf
can you tell me which wires to connect the door lock harness to?
Edit: Also my check engine light is on now but the autopart store said there are no codes to read.
