oooo boy... heater core?
Old Sep 23, 2011 | 07:24 PM
1998ram5.9's Avatar
1998ram5.9
Default oooo boy... heater core?
Ok so the problem im having is when i start the truck and turn the heat on i smell that sweat anti freeze smell and the windows fog up bad and gets a film all over the wind shield. Its also a alittle moist on passenger side floor. The heat works amazing tho! I crank it up and it slowly starts to defrost window but it takes a long time. Can i get lucky and maybe flushing the sytem will correct this? I always thought if the heater core was going the heat would not be great. thanks guys
Old Sep 23, 2011 | 07:56 PM
As the coolant leaks out on the floor, your heater will lose efficiency. Of course, your engine will also run hotter.
As you are in the snow belt, I highly recommend replacing the heater core...... don't bother with a bandaid fix, you will only get the opportunity to replace the core anyway, when it's five below outside.
Old Sep 23, 2011 | 08:42 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The heater core is leaking, simple as that. Needs to be replaced. Flushing it will probably make it leak worse. Start searching for the HC replacement threads.
Old Sep 23, 2011 | 10:40 PM
RageGuy's Avatar
RageGuy
I grabbed the $75 core with the swivel pipes from auto zone, works great, no complaints.
Some people around here flame me for it saying I should have spent $200+ for the "higher quality" dealer one, but F that.
The $75 one looks exactly the same...just doesn't have a Mopar stamp on it... big freaking deal.
If you need some pointers PM me, I just went through this 2 weeks ago, would be happy to help. Entire job start to finish took an afternoon, no big deal, its really not as much of a PITA as some make it out to be, an extra set of hands helps if available
Total cost was:
$75 for the core
$15 for 20ft of heater hose
$40 for coolant to refill afterwards
Thats it. Sure beats the $600 the mechanic wanted for the job...
Old Sep 24, 2011 | 01:19 PM
1998ram5.9's Avatar
1998ram5.9
Total cost was:
$75 for the core
Ok thanks man im sure ill be sending you a pm i think im gonna get at this next weekend. Im just wondering with it beeing a base model truck, its not even the slt, is it easier to get to the heater core. I can actualy see some of that heater box from inside the truck
Old Sep 24, 2011 | 01:21 PM
zman17's Avatar
zman17
Doesn't matter what model you have. They all suck to get to.
Old Sep 24, 2011 | 01:22 PM
1998ram5.9's Avatar
1998ram5.9
Yep i agree i was just suprised a failing heater core would put of good heat still.
Old Sep 24, 2011 | 01:23 PM
zman17's Avatar
zman17
It's still flowing obviously, just has a leak.
