33x12.50 with lift but still rubbing
Old Sep 24, 2011 | 09:10 PM
96magnum's Avatar
96magnum
Default 33x12.50 with lift but still rubbing
whats up dodgeforum.com
im new here and needing a little advice.. i have a
4wd 96 ram 1500 single cab and has 33x12.50 r15 brute
mud tires on 15" pacer wheels. i have a 2.5 inch suspension lift
but im still rubbing pretty hard... what are some options to fix this?
pics would help too.. thank you!
Old Sep 24, 2011 | 09:13 PM
SilverSS's Avatar
SilverSS
What's the backspacing on the wheels? Where is it rubbing? How wide are the wheels? On another note got any pics of the truck?
Old Sep 24, 2011 | 09:21 PM
96magnum's Avatar
96magnum
backspacing is 3.75...rubbing mostly on front left inner fender closest to the door
Old Sep 24, 2011 | 11:17 PM
Trim the plastic there.
Shouldn't be rubbing though..... how do your control arm bushings look?
Old Sep 25, 2011 | 01:55 AM
Wombat Ranger's Avatar
Wombat Ranger
What 2.5" lift is it?
Old Sep 25, 2011 | 05:13 PM
96magnum's Avatar
96magnum
arms look fine.. what would you recommend trimming the plastic with?
and the lift is pro comp
Old Sep 25, 2011 | 05:28 PM
zman17's Avatar
zman17
Retired Moderator - RIP
A cut off wheel???
Old Sep 25, 2011 | 06:03 PM
dsertdog56's Avatar
dsertdog56
Basicly he has a front spacer and AAL. With 3.75 backspacing (scrubsteer) and an uncentered axle he probably is hitting the left inner fender.
When trimming the inner fender be cautious of the electrical plug under it.
