vacuum leak?
Old Sep 26, 2011 | 04:10 PM
71dodge's Avatar
71dodge
yea its 4x4 but all the transfer case lines are hooked up? and its a hard line and not even long enough to reach the transfer case
Old Sep 26, 2011 | 04:16 PM
71dodge's Avatar
71dodge
could it go behind the motor?
Old Sep 26, 2011 | 04:27 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The white line is the vac for the switch on the transfer case. It must be broken . And last chance to add ALL the info about your truck to your sig. lol
Old Sep 26, 2011 | 04:29 PM
71dodge's Avatar
71dodge
now were does it sit? and can i buy a new one?
Old Sep 26, 2011 | 04:34 PM
zman17's Avatar
zman17
It goes from one of the tees/ elbows on the passenger side mess of vac lines and is usually taped to the main wire harness running behind the motor. It does go down behind the motor to the switch on the TC.
And thank you
Old Sep 26, 2011 | 04:40 PM
71dodge's Avatar
71dodge
were is the switch on the transfer case at? theres no way that line is long enough to reach the transfer case?
Old Sep 26, 2011 | 04:47 PM
On top, by where the shift linkage hits it.
Old Sep 26, 2011 | 04:58 PM
zman17's Avatar
zman17
I thought you said this?
Anyway, follow the red and black lines from the CAD on the front axle and you will come to the switch. It has a rubber plug with four plastic lines . From the switch, Red and black go to CAD, white is supply vac and a green one that ends with a check valve on the end , which does not connect to anything.
Old Sep 26, 2011 | 05:15 PM
71dodge's Avatar
71dodge
were does the green line run to on the motor.? there all brittle and keep breaking off and i dont know were the green one broke off at
Old Sep 26, 2011 | 06:04 PM
71dodge's Avatar
71dodge
anyone??? im in a rut and have no clue were this green vac line runs
