starting problem..
Old Sep 27, 2011 | 12:59 AM
jlowmiller's Avatar
jlowmiller
Originally Posted by John D in CT
"Wow, start off with some punctuation and grammar".
I find it odd that punctation and grammar could keep a truck from starting, but I guess I've seen stranger things ....
Hey, regardless of what the boys down at Autozone think, it sounds very much like your starter is bad; specifically, the solenoid drive. The symptoms fit that perfectly.
Sometimes a starter can seem OK when you hit it with 12 volts on a bench, but not get the job done when it's in the vehicle.
I'm lucky to have a father-and-son auto electric shop 1/4 mile away from my shop that does nothing but rebuild starters and alternators in-house. They test my stuff, and even let me take a starter, alternator or battery if we're not positive what's defective, and bring back whatever I don't need. If Autozone won't do that for you, try to find someone who will.
Good luck, and please let me know if it was in fact the starter.
I agree with John, sounds like the starter is either not hitting the drive plate right or the Bendix isn't moving and its just spinning.
Coming out and spinning is all fine and dandy until you try moving a beast of drive plate over under compression.
Edit: You did say you heard a whirring sound correct?
Old Sep 27, 2011 | 07:19 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Hope a new starter gets you going.
On a side note, looks like somebody has some sort of problem with some one else on DF. Enough already!
Old Sep 27, 2011 | 04:27 PM
drtbker13's Avatar
drtbker13
When i turn the key it only clicks once then nothing. But sometimes none of this even happens and just turns over and starts.
Old Sep 27, 2011 | 06:09 PM
zman17's Avatar
zman17
Since you say you checked all the connections. I have to say it's time to remove and replace the starter.
Old Sep 27, 2011 | 06:13 PM
drtbker13's Avatar
drtbker13
I checked again yesterday when i got home. I guess I will go look around. What is a good place buy a good starter thats semi cheap?
Old Sep 27, 2011 | 06:19 PM
zman17's Avatar
zman17
Just get one from your local parts store that has a decent warranty, in case it goes bad.
Old Sep 27, 2011 | 06:25 PM
drtbker13's Avatar
drtbker13
Alright. I will keep you guys posted on what i do.
Old Sep 27, 2011 | 06:39 PM
blkjack's Avatar
blkjack
truck wont turn over , check engine light blinks 10 times then all lights in dah come on
Old Sep 27, 2011 | 06:43 PM
zman17's Avatar
zman17
HUH? I leave this one to John D in CT .
Old Sep 27, 2011 | 06:46 PM
drtbker13's Avatar
drtbker13
I do not understand what he is saying?
