Causation of magnum head cracking.
Old Sep 28, 2011 | 02:52 PM
jlowmiller's Avatar
jlowmiller
Default Causation of magnum head cracking.
Has anyone ever figured out why these heads crack? Is there any correlation between plenum failure and head damage?
Old Sep 28, 2011 | 02:57 PM
CPTAFW163's Avatar
CPTAFW163
They are poorly cast. Plenum has nothing to do with it.
Old Sep 28, 2011 | 03:01 PM
97tn4x4's Avatar
97tn4x4
Not entirely true, the plenum fails which leads to burning oil which leads to clogged cat which leads to cracked heads.
Old Sep 28, 2011 | 03:04 PM
The heads can crack even without the blown plenum. They were just **** poor castings, decks were too thin. There are better heads available in the aftermarket, for under 300 a pop.
Old Sep 28, 2011 | 03:06 PM
jlowmiller's Avatar
jlowmiller
So additional oil leaking into the air intake would also cause undo hydro compression on the heads, assisting with the stress?
Old Sep 28, 2011 | 03:07 PM
Nah, the burning oil clogs the cat, so cylinder temps go up... making cracks more likely.
Old Sep 28, 2011 | 03:09 PM
jlowmiller's Avatar
jlowmiller
I knew there were several theories out there, clogged cat, bad castings.. so I just wanted the pro's takes
Old Sep 28, 2011 | 03:16 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Just blame George Bush.
Old Sep 28, 2011 | 03:22 PM
jlowmiller's Avatar
jlowmiller
LOL Which one?! So many to choose from.. and so much blame to go around.
Old Sep 28, 2011 | 03:23 PM
CPTAFW163's Avatar
CPTAFW163
Lets chase this rabbit down the hole even further.
Clogged cat, leads to higher cylinder temps, leads to higher exhaust temps, leads to cracked exhaust manifolds or leaky gaskets, which leads to a slight amount of winter air to go in through the leak before the compression cycle, which is too cold and makes the exhaust valve crack....
