Alot of Exhaust Questions, Just wanna finalize this
Old Sep 29, 2011 | 02:36 AM
sethcorn's Avatar
sethcorn
Question Alot of Exhaust Questions, Just wanna finalize this
Thank eveyone for reading my thread. I've done alot of research and since everyone's setup tends to be a little bit differnt I figured I'd start my own topic.
First, I have a 1999 Dodge Ram Quad Cab 4x2 Dodge Ram 5.9L.... I want a SI/SO exhaust system with a decent looking stainless steel tip.
1. Is it center in/ offset out? Is the exhaust pipe measured in diameter? Im probably an idiot, but the stock pipe I have measures 3 1/2 on the tape. I bought this one owner from an old retired man, who I know didn't replace the stock pipe he even told me so.
2. The muffler I need is it 2 1/2 in and 2 1/2 out? Honestly could care less about the whole which size is better out argument. Do I want to go a size bigger so it slips over the stock pipe? I plan on welding it, unless bolton would work?
3. The tip, I just want it to be simple and look like it belongs, im gonna dump the exhaust in the stock location. Tip size do I want the inlet size the same as the pipe or bigger so it slips over the stock pipe?
Im looking at Magnaflow or Flowmaster 50 series.
All and all im just curious about your experiences, and what you think would work, I have a pretty good idea on what I want, but just curious of your input. Thanks for repsonding!
Old Sep 29, 2011 | 09:39 AM
You want to get parts for your size pipe. Manufacturers take that into account when making the various parts. So, a muffler for a 2.5 inch exhaust system will fit over 2.5 inch pipe. If you go for the larger sizes, you will have some nice gaps to fill when you weld it up.
Pipe is measured by inside diameter.
Where the inlets/outlets are is just a matter of preference. Get the one you need to run the exhaust the way you want it.
Old Sep 29, 2011 | 10:06 AM
zman17's Avatar
zman17
Retired Moderator - RIP
This may help a little with the sizes.
https://dodgeforum.com/forum/2nd-gen...ram-1500s.html
Old Sep 29, 2011 | 08:32 PM
sethcorn's Avatar
sethcorn
Thanks guys! I appreciate it! What about tips do they follow the same rules as mufflers as far is they will slip the same size pipe if I go with a weld on?
Old Sep 29, 2011 | 08:35 PM
Yep. They are actually pretty uniform in that across all manufacturers.
Old Sep 30, 2011 | 09:41 PM
sethcorn's Avatar
sethcorn
Again thanks for the replies! Here is what I ended up going with! Im pretty stoked.
Flowmaster 50 Series Delta Flow
http://www.summitracing.com/parts/FLO-842551/
Exhaust Tip
http://www.summitracing.com/parts/MPE-35205/
Gonna get the highflow cat probably after this winter, Doesn't look like that big of a job, even though it woulda prob been easier just to go them all in one job. Oh well I got a good hometown exhaust shop.
