new XRF adjustable track bar
Old Sep 29, 2011 | 08:01 PM
seabass202's Avatar
seabass202
Default new XRF adjustable track bar
Hey guys, just got an adjustable track bar from XRF. Nice piece. It is solid steel with alot of adjust ability and will compliment my new one ton steering upgrade nicely. now my question is this, it doesn't have a grease fitting. can I drill and tap in a grease fitting (zerk) or do things inside the joint, like channels for the grease to move about need to be there which may not be? of course I would be very careful as to not introduce metal shavings to the joint etc. while doing this. or should I just run it without? 171.00 shipped from XRF as there are no dealers in Florida. please advise. Thanks, Jeremey
Old Sep 29, 2011 | 08:23 PM
zman17's Avatar
zman17
Retired Moderator - RIP
A $400 Thuren Trac Bar doesn't have greasable joints either. And it doesn't need to be greased. It's a better joint that doesnt need to be. If the XRF has the same joints, I'm betting it doesn't need greasing either. Have you looked on there website for info regarding your question?
Old Sep 29, 2011 | 08:39 PM
seabass202's Avatar
seabass202
no, I haven't. will do.
Found this on a diesel website:
My XRF lowers have grease zerks.
When I called them they said in their experience they get better life out of a sealed unit thats built properly than one with zerks. They say most guys will shorten the life because they will pump any old goop they have in the grease gun.
I don't know if I buy into that thinking myself but they must not put zerks on for a reason?
Old Sep 29, 2011 | 08:59 PM
J415's Avatar
J415
Let me just say that I installed new upper and lower XRF ball joints and I'm VERY PLEASED with the quality of the ball joints. I think you'll be happy with your track bar.
Old Sep 29, 2011 | 09:03 PM
Ah, but, did they have zerk fittings?
Old Sep 29, 2011 | 09:15 PM
J415's Avatar
J415
Are you kidding me?!?! The zerk fittings had zerk fittings!!! How do you like them apples?!
Old Sep 29, 2011 | 09:17 PM
Apples are good, zerks are better.
Old Sep 29, 2011 | 09:22 PM
zman17's Avatar
zman17
LOL, you can grease them while filling up at the pump they are so long.
Old Sep 29, 2011 | 09:41 PM
I have seen folks run lines from all of their zerk fittings.... to a central location under the hood...... then just hop from zerk to zerk when doing the oil change thing....... Personally, I thought that was a bit berZERK......
Old Sep 29, 2011 | 09:53 PM
seabass202's Avatar
seabass202
I am screwed then, I am getting Death Wobble just reading this.
