electrical problem please help
Old Sep 29, 2011 | 10:04 PM
Headlights get power from the PDC directly. If they don't work at all, then you are losing connection between the battery, and the PDC.
Old Sep 29, 2011 | 10:11 PM
cutthroatxxx's Avatar
cutthroatxxx
it just happend again &wont start...no lights no radio no horn nothing.
Old Sep 29, 2011 | 10:12 PM
Check the battery cable from the battery, to the PDC.
Old Sep 29, 2011 | 10:14 PM
cutthroatxxx
I did
Old Sep 29, 2011 | 10:15 PM
Then you have a problem in the PDC itself...... that should be fun to find......
Old Sep 29, 2011 | 10:41 PM
cutthroatxxx
Thanks alot for helping me with this I appreciate it!I think its a short in the pos cable.Gkt it started again.Ill replace it this weeknd.
Old Sep 29, 2011 | 10:42 PM
Let us know what you find.
Old Sep 29, 2011 | 10:45 PM
cutthroatxxx
Will do.
Old Sep 30, 2011 | 02:17 AM
bbgundave's Avatar
bbgundave
Do a battery test.
Just got a truck that had a bad battery.
The battery would start the truck.
But was it just enough too get it to run.
Soon as I tried to move it the computer hicuped and the motor died.
Lights worked / fans worked (ac).
The computer needs a stable power source.
If the battery is not up too the job the truck will fail,
Old Sep 30, 2011 | 04:25 AM
peshewa's Avatar
peshewa
To add to that, I had that exact problem in a caravan I used to own. All terminals fuses & connections looked great, but I came to find out the positive post was broken inside the battery. If I tried to pry up just a little on it, the post would come all the way out, it was detatched from the plate in the battery. A new battery fixed that issue for me. Good luck!
