possible E-Fan
Old Sep 30, 2011 | 04:18 PM
BackwoodsRam's Avatar
BackwoodsRam
Default possible E-Fan
has anyone tried using the Efan out of a 2000-2002 grand cherokee? ive been readin on a couple other forums of people using them. i already ordered one sice they were only 70 after shipping from dodgeparts.com. and i dont mind running a second fan if i need to since i already orderd a haden single/dual fan controller
Old Sep 30, 2011 | 04:27 PM
CPTAFW163's Avatar
CPTAFW163
let me know if it fits. For 70 bucks it is worth an experiment (especially since direct fits run 300-600 for our trucks).
If the dimensions are the same as the radiator, then it will work. If it does not cover the whole radiator, then you might have issues.
I had a Grand Cherokee, I don't remember the shroud being that big. BUT, you might be able to "improve" the shroud so that it pulls air through the total area of the radiator.
Old Sep 30, 2011 | 04:30 PM
BackwoodsRam
the fan is a 19 inch fan and im thinking about using our trucks stock shroud and making a mont bracket to hold it in place since the shroud opening is 22" iirc and the usw weather stripping or something to make it seal
Old Sep 30, 2011 | 04:36 PM
CPTAFW163's Avatar
CPTAFW163
Ah, I thought it was a dual setup. THe only single fan that can turn enough CFM for our trucks would be This fan: $269.99
http://moesperformance.com/index.php...r_of_uploads=0
3300 CFM. What is the rating for the 70 dollar one?
Old Sep 30, 2011 | 04:38 PM
BackwoodsRam
theres no definte number but theres alot of dakota and chebby guys running them that claim mid 3500s to 4000 cfm
Old Sep 30, 2011 | 04:40 PM
CPTAFW163's Avatar
CPTAFW163
it is worth a shot then.
Old Sep 30, 2011 | 04:42 PM
BackwoodsRam
lol thats what im thinkin, besides even if it only pushes 2k or so of cfm then thats still a good price and i can just get another fan to help it out
Old Sep 30, 2011 | 05:06 PM
Hahns5.2's Avatar
Hahns5.2
I am. Fan sits about an inch off the rad, no shroud, keeps coolant temps between 180-190º on 95º days sitting in traffic with the AC on. Great fan.
Old Sep 30, 2011 | 10:10 PM
SilverSS's Avatar
SilverSS
Ford Taurus fan is about 4500 cfm and Lincoln Mark VIII fan is 5000 cfm. You can pick them up from the junkyard or ebay for usually $50 or less . I'll get around to doing that eventually .
Old Oct 1, 2011 | 12:15 AM
jasonw's Avatar
jasonw
Site Moderator
Actually, most of the part numbers I have found around the net state that the Ford Taurus fan and the Mark VIII fan are the same part numbers, and therefore the same fans. There are conflicting reports of whether they blow as "low" as 4500 CFM, or as high as 5500 CFM.
Here's the killer.
They draw around 33A while running, and when cold over 100A to start up! No thank you. My setup (and others that use good branded aftermarket units) may cost more, but use much safer amperage.
