stuck in 2nd gear
Old Sep 30, 2011 | 05:30 PM
bps7576's Avatar
bps7576
Default stuck in 2nd gear
I have a '99 dodge 3500 slt dually automatic-5.9l cummins. the other day as i was pulling out of the drive, the truck began to shift through the gears and stopped on 2nd (max speed 20 mph). I tried giving it more throttle-which it didn't shift, then i backed off the throttle- it didn't shift. also, last week i started to notice that when going into overdrive, it would shift to early. any thoughts about what the issue could be? any help would be apprectiated! thanks
Old Sep 30, 2011 | 05:41 PM
gdstock's Avatar
gdstock
Don't know about that transmission, but with the trans on 5.2L, I would suggest to check fluid level in trans. My trans has to be done in Neutral, ot in park. It may be a front band adjustment.
Go to the DIY secion and there is a link for a 2001 Factory Service Manual. HSould be the same. Download that and check the trans section.
Welcome to DF.
There will most likely be someone along with more experience on these transmission that I have that could give you a better idea, but the manual if a great reference.
Good luck.
(zman made me do it....)
Old Sep 30, 2011 | 06:34 PM
bps7576's Avatar
bps7576
thanks i'll give a look and let ya know.
Old Sep 30, 2011 | 06:40 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Governor solenoid is bad or clogged I'll bet.
Old Oct 3, 2011 | 12:28 PM
bps7576's Avatar
bps7576
i just replaced the control soleniod and fluids and the filter while i had it apart, but i'm still having the same problem.
Old Oct 3, 2011 | 12:32 PM
Reset the PCM.
Old Oct 3, 2011 | 12:36 PM
bps7576's Avatar
bps7576
not sure how to do that.
Old Oct 3, 2011 | 01:09 PM
bps7576's Avatar
bps7576
i got it! thanks everybody so much! i'm in busy again!
Old Oct 3, 2011 | 01:30 PM
Did the reset do the trick?
Old Oct 3, 2011 | 03:36 PM
bps7576's Avatar
bps7576
yes it did. thanks so much. i didn't think of that.
