Cruise control revving
Old Sep 30, 2011 | 11:08 PM
klings designs's Avatar
klings designs
Default Cruise control revving
98 ram 5.2. When I have cruise control on my rpms jump up 200-300 rpms couple times a minute.
Old Sep 30, 2011 | 11:18 PM
TPS....... Probably. You can check it with an Analog Volt meter, or, a scan tool that will show data.
Old Sep 30, 2011 | 11:30 PM
klings designs
I thought I checked it once and the readings were pretty accurate.
Old Oct 1, 2011 | 08:38 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You checked it because you were having this problem?
Old Oct 1, 2011 | 08:41 AM
bwdakrt's Avatar
bwdakrt
Bad TPS. Been there...done that.
Old Oct 1, 2011 | 09:46 AM
aim4squirrels's Avatar
aim4squirrels
Might have a vac leak in your cruise control line, but I would bet tps first as well.
Old Oct 1, 2011 | 10:56 AM
klings designs
I checked it a couple months ago. I was having problems with my truck surging. Sometimes when I take off it seems like it's not getting gas so if u step on it. It runs fine. Also when I put sea foam in the gas it runs a little better.
Old Oct 1, 2011 | 11:14 AM
zman17's Avatar
zman17
I'd check it again or replace like has been suggested. You also should clean the TB and the IAC.
Old Oct 1, 2011 | 11:17 AM
Sheriff420's Avatar
Sheriff420
While you're poking around in the engine bay you should inspect your spark plug wires for cracks. While it's normally the TPS, sometimes it is cracked insulation on a spark plug wire or two.
Old Oct 1, 2011 | 11:22 AM
klings designs
I will swap out tps. I changed plugs wires cap rotor. Fuel pump. Map sensor. Coolant sensor.
