cylinder 1 misfire
Old Sep 30, 2011 | 11:22 PM
80omni's Avatar
80omni
Default cylinder 1 misfire
i have had a cylinder one misfire on and off for the past 2 months now. it only misfires at idle. i have switched the plug to another cylinder and the wire aswell but the misfire stays at cylinder 1. the only way i can get it to temporarily go away is if i reset all adaptives, but that lasts about a month.
im goin to switch the injector to a different cylinder and look closely for a possible intake leak or a cracked head.
was wondering if anyone had any insight as to what else to look for, thanks
Old Sep 30, 2011 | 11:40 PM
lastrights's Avatar
lastrights
When the last time u changed the cap and rotor , it may not be getting a good contact
Old Oct 1, 2011 | 12:01 AM
80omni's Avatar
80omni
oh i changed the cap and rotor aswell as the plugs and wires when i did the plenum about a month ago sorry
Old Oct 1, 2011 | 07:37 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You might also try routing the wires in this fashion, http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
