01 5.9 no signals to coil Help
YAY!
Thank You All Very much!
About 1 hour to install, It is a tuff spot I had a good time working over the rear corner of the Passenger Valve cover. Not a fun Job but not the worst Either!
Thanks again for the Facts and info I needed!
Purchased the Part from Pep Boys so it was BWd.
We probed the Coil input before trying to start so We knew we had it as soon as I had my switching Negative and a nice strong Positive while Cranking!
YAY Life is good!
Big thanks Again! Now off to work on that old Land rover thats been sitting since last winter!
YAY Life is good!
A van obviously has more room between back of block and the heat shields on the firewall OR your hands are smaller than some of the rest of us or both.
The back of my hands after installing crank sensor looked like I tried to stuff a cat into a bottle.
Crank sensor is easy on my Dakota too.
YAY!
YAY Life is good!
YAY Life is good!
Congrats! I am always glad when someone comes to DF with a problem, and gets help to be able to fix it. That's why I come here. I even read through threads for which I am not experienceing a problem - so that when i do, I know what to do!
Thanks again to all, Could not have solved it without all the great info and facts Which I received very quickly here! You guys are the best!
Thanks for taking the time to help and share what you know!
You're very welcome; these guys really do know their stuff. This sure is a great site that helps a lot of people; glad you were one of them.
