305/70/16 on 7.7 inch wheel?
Old Oct 2, 2011 | 11:12 AM
mccart's Avatar
mccart
Default 305/70/16 on 7.7 inch wheel?
Can i put a 305 70 16 tire on a stock 7.5 inch wide wheel? Ive heard of people doin it with a hummer but not anything with a truck. Also what can i do to stop the rubbing on the torsion bar when i turn? Because I have 285 75s on it now and they rub a little
Thanks
Old Oct 2, 2011 | 12:14 PM
Going to a wider tire is only going to make the rubbing worse. Look at the specific tire you have in mind, and it should have a "Recommended Rim Width". Probably going to be a minimum of 8 inches...... being only a half inch off? Maybe bad, maybe not. Up to you, and the tire shop. (they may not want to install them on undersized rims.... liability concerns don'tchaknow....)
If you have a half-ton truck, the front axle MIGHT have adjustable stops, so you can limit how far you can turn the front wheels, and avoid the rubbing. (but, increasing your turn radius some....)
Welcome to DF!
Old Oct 2, 2011 | 03:12 PM
mccart's Avatar
mccart
it is a 1/2 ton, its a 97. The recommended width for the tires is 8-10 inches. I guess an offset wheel would help
Old Oct 2, 2011 | 07:19 PM
A wheel with less backspacing would stop/reduce rubbing at the control arm, but, you might find that it rubs somewhere else now..... (inner fender well most likely, or, the bumper....) Also keep in mind, that less backspacing is going to alter the loading on your front hub/bearing assembly....... and it may not care for that over much. (which would lead to them failing more often than they normally do....) Of course, if it's 2wd..... then it isn't quite so critical, as the bearings themselves are replaceable, and you don't have to get the whole thing. (cheaper too...)
You should really put all the info on your truck in your sig. Makes us helping you much easier, and you don't have to answer the same question each time. (where's zman??)
Old Oct 3, 2011 | 10:09 PM
mccart's Avatar
mccart
how do i write in my sig? cant figure it out
Old Oct 4, 2011 | 12:02 PM
Click on "User CP" in the upper left, that will bring you to another page, if you look down the column on the left side, there will be "Edit Signature", click that one. Should be golden.
Old Oct 4, 2011 | 01:08 PM
zman17's Avatar
zman17
Retired Moderator - RIP
And fill out your profile with the same info. This way if you are using a cell, the info will show there.
Old Oct 4, 2011 | 10:06 PM
mccart's Avatar
mccart
thanks, i decided im going to get new wheels. I want to try to get a wheel that will sit out farther, do i want higher offset or rear spacing? cant really figure out whats what.
thanks
Old Oct 4, 2011 | 10:18 PM
chadhager03's Avatar
chadhager03
Did I fill put my profile? I always use my cell and I can't see anyone's profile or sig, or can I?
Old Oct 4, 2011 | 10:43 PM
I see your profile info Chad.
@mccart: You want less backspacing. Stock is 4.5 inches. What size wheel do you want?
