How do you like the lights? Hella 500ff
Old Oct 2, 2011 | 04:35 PM
chadhager03's Avatar
chadhager03
Default How do you like the lights? Hella 500ff
I installed these lights about 2 weeks ago and I love them. They put out a lot of light but I want more! Would it be bad if I put 2 lights in-between these two? I want to put two more 500ff's and they would fit but I'm worried about it restricting the airflow
Old Oct 2, 2011 | 04:48 PM
John D in CT's Avatar
John D in CT
Pic links aren't clickable, I had to cut and paste them into my address bar.
Lights look cool; they work fine shining through the grill?
Old Oct 2, 2011 | 05:15 PM
chadhager03
Oh sorry about that, I'll try again. Ya they work amazingly well through the grill. With the hood up it doesn't put off too much more light but I like how they are hidden.
Old Oct 2, 2011 | 05:31 PM
HammerZ71's Avatar
HammerZ71
You can add two more, or pull the 55 watt bulbs and replace them with a couple H3 100 watt bulbs (about $5 each at any auto parts store), a lot easier and only 10 watts less total light output. Just make sure the wiring, fuses and relay are up to about a 17 AMP draw as oppose the the approximate 9 AMP draw you have now...
Oh and I fixed your pics too, you can thank me later... LOL...
Old Oct 2, 2011 | 05:45 PM
chadhager03
well those are the "driving lights" and I would think the "fog" light versions would be a nice compliment. Thats a good idea though, I will consider that or put hid's in them. So no one thinks it will cause a heat issue?
Old Oct 2, 2011 | 07:27 PM
HammerZ71's Avatar
HammerZ71
Nah, the 55 watt Hellas don't generate much heat at all. Funny thing is the 100 watt bulbs aren't much hotter but you put another brand of 100w lights behind the grill and they get HOT. Dunno what Hella does.
At 55 watts x 4, you'll only pull about 18 AMPs, so you can run them off the same relay if it's a standard 30 or 40A one. I'd just go 25A on any fuses if you do wire them all together. I've setup four Hella 500s on a couple of Jeeps for friends and had no problem running them all together and off one $5 relay. It's when you get up into multiple sets of 100W or greater lights you gotta start daisy chaining relays for one switch to work them all...
Old Oct 2, 2011 | 08:11 PM
dodgeramit_10's Avatar
dodgeramit_10
I just installed the hella 500 fog lights amazing. bought the driving lights at the same time gatta weld a bracket on the gaurd to put them on yet. probably ganna upgrade to HID on both pairs upgrade the headlights and put actual fog lights in the stock spot just for $hits and giggles.
Old Oct 2, 2011 | 08:12 PM
chadhager03
Well that's not too bad, I guess I'll just get two more and stick them in there. Thanks for the quick response!
Old Oct 7, 2011 | 08:25 AM
kadetklapp's Avatar
kadetklapp
I've got a pair of Hella 500s on the brush guard. I had them laying around the garage for a year and when I bought the truck I knew where I could finally throw them-
Old Oct 7, 2011 | 08:38 AM
mclark754's Avatar
mclark754
i got 3 sets they dont get too hot i like them
Attached Thumbnails How do you like the lights? Hella 500ff-300154_270978759586045_100000217687501_1328311_7537572_n.jpg
