cv joint replacement???'s
Old Oct 6, 2011 | 06:22 PM
nzRAMIT's Avatar
nzRAMIT
Default cv joint replacement???'s
in my 99 ram 1500 i have a crunchung noise coming from the pass front tire when turning at low speeds....with a buddy inching along with the wheel cut i narrowed it down to most likely being the cv joint......HOWEVER...parts are not even listed as available for the shaft, joint itself or anything!!! can i replace just the joint itself and match one up based on bearing cap/overall measurements??? any info will be appreciated
i did consider the bearing/hub as the root of the noise, most likely not it
Old Oct 6, 2011 | 06:33 PM
dhvaughan's Avatar
dhvaughan
look under Driveline - Axle U-joint, not CV-joint. you get what you pay for, and its a sizeable job, so get good ones, either Precision Brand or Spicer or something else in the $20-30/ea range. don't get the $10 chinese, or you'll be redo'ing them within a year.
http://www.pavementsucks.com/tech-article-5.html
http://napaonline.com/Catalog/Catalo...377_0275676020
Old Oct 6, 2011 | 06:39 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Get a Haynes manual or download the service manual from the FAQ/DIY section. Buy a simple ujoint (from any parts store) and replace it.(there's no measuring involved) Tell the store which joint you want , and they will hand it to you . It's NOT a CV joint like you are thinking.
And I don't know what store you are going to, but, I'd find a different one.
Old Oct 7, 2011 | 12:30 PM
nzRAMIT's Avatar
nzRAMIT
AutoZone, but after reviewing the manual, it's about what I expected, just gotta search for the parts I guess, thanks
Old Oct 7, 2011 | 01:58 PM
matty675's Avatar
matty675
use the socket trick to remove the u joints.
but before you go wailing on 'em with a hammer, be sure to remove the c-clips at the bottom of the caps.
Old Oct 7, 2011 | 05:18 PM
zman17's Avatar
zman17
Search? I looked on the autozone site. One part listed, pretty simple. Of course I wouldn't use Duralast joints, but I had no problem finding the joint. http://www.autozone.com/autozone/par...26_0_1439_5247
