Really weird stumbling problem
Old 10-08-2011 | 01:29 PM
Hahns5.2's Avatar
Hahns5.2
Originally Posted by zman17
Do a vacuum test, and see how the gauge reacts with cold engine vs. hot.
Yeah, it would be good do see if the gauge matches what the MAP says it's doing. If not, it's the MAP.
Old 10-08-2011 | 03:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Can't help with the ARP bolt's. But, did you stick a vacuum gauge on it?
Old 10-08-2011 | 03:50 PM
aim4squirrels's Avatar
aim4squirrels
Swapped the MAP sensor, no change.
Got a question a about the head gasket:
I'm using ARP head bolts and according to their literature and the tech I called, they should be torqued to 100 ft/lbs. dry, which is what I did. That's 5ft/lbs. Less than stock. Is it possible the head gasket did not compress enough and is causing a vac leak of some sort? As stated earlier, there is none of the typical signs of head gasket leak. Is there a possible problem there?
Old 10-08-2011 | 04:01 PM
zman17's Avatar
zman17
Originally Posted by aim4squirrels
Haven't had a chance yet, Zman.
I had to take it to get inspected. I passed, LOL.
well that's a good sign anyway.
I don't know what you have for a vac tester, but, if you like. I'll copy the diagnostic/troubleshooting specs from my Mighty Vac manual.
aim4squirrels
Old 10-08-2011 | 05:09 PM
aim4squirrels
I've seen a couple websites that have vac gauge interpretations. Let me know if this website wings true to your mighty vac manual:
http://www.secondchancegarage.com/public/186.cfm
I liked it especially for the diagnostic section at the bottom that displays what the vac gauge reads and what it might mean.
Old 10-08-2011 | 05:46 PM
zman17's Avatar
zman17
Old 10-09-2011 | 11:28 AM
aim4squirrels
Well,
No testing this weekend, it's pouring buckets outside. Really nutty weather, but we need the rain badly, so I'll deal with it for another week.
Old 10-10-2011 | 11:53 AM
aim4squirrels
Got a break in the rain, here's what it's doing on a cold engine:
https://www.youtube.com/watch?v=-oQm...e_gdata_player
I'll get the hot engine in a bit when I run out to get a longer vac hose. Sorry for the crappy angle.
idles right around 15 "Hg, which I'm told is acceptable for my camshaft. That tip in off idle is what's herring me, I think.
Old 10-10-2011 | 12:19 PM
zman17's Avatar
zman17
Sorry, damn dbl post.
Quick Reply: Really weird stumbling problem
