Help identifying part.
Old Oct 8, 2011 | 06:37 PM
Tyler.'s Avatar
Tyler.
Default Help identifying part.
Ok so i need to know what this part, or sticker is called i have searched around and have had no luck. They are just worn away and look bad, so i want them replaced. Here are the pics.
Old Oct 8, 2011 | 09:52 PM
UnregisteredUser's Avatar
UnregisteredUser
That's called a "B-Pillar Blackout".
Old Oct 8, 2011 | 10:44 PM
J415's Avatar
J415
Or to the common folk...black paint...
Old Oct 26, 2011 | 11:31 PM
Tyler.'s Avatar
Tyler.
Bringing this back up, but would they be easy to remove and replace?
Old Oct 26, 2011 | 11:48 PM
I am hoping he means PAINT.
Old Oct 26, 2011 | 11:49 PM
wyomingdodge7's Avatar
wyomingdodge7
They peel right off, and can easily be replaced with black automotive pain, had it done on my truck just a few months ago.
Old Oct 27, 2011 | 12:02 AM
wyomingdodge7
Haha that one little "t" sure does change that sentence quite a bit.... lol
Old Oct 27, 2011 | 02:02 AM
peshewa's Avatar
peshewa
In body shops, they use a large tan rubber eraser wheel with a collet in the middle on a drill to literally erase stickers off a vehicle without removing pain as long as the paint is not less than 30 days old on the truck. They cost about $15.00 or less & can be had form an auto body supply shop. Then you can either paint or just put new generic black decal material on & cut off the excess. I would suggest removing the rubber trim that borders the sticker before you use the eraser wheel, then just put it back in when you have restuck new sticker or painted it. If you paint it, I highly suggest you look up some of the threads on doing paint correctly, using a good sealing primer, wet sanding etc between layers or the paint may not stick for more than a year or 2 also. I did used to do a lot of auto body back in the day, but without a shop in my driveway I spent about 4 hours making it look really nice & it wont peel anytime soon. Then again, I would not be against anyone using the generic black sticker material also. Either option can be made to look very nice. Good luck!
Old Oct 27, 2011 | 08:28 PM
Tyler.'s Avatar
Tyler.
Well i started to peel some away, the residue rubbed away with my finger nail, so i am going to remove them both this weekend. I think i might like it without them, but if i don't i can always buy replacements because these have already worn away.
