P0118 after water pump change
Hey yall. I changed my water pump yesterday and now im getting code P0118. The code will not reset. I didnt doanything to my ect sensor during the water pump replacement. Also if i turn my key to the on position but leavethe engine off my temp gauge constantly reads 190ish but if i start the truck the gauge slowly works its way down below the 130 mark. My ect sensor was replaced about 8monthsall ago. Any ideas on what could be causing this? Also i have a new 195 dgree tstat in the truck, and i tested it before i installed it. The code pops up no mater how hot or cold the motor is
Also i dont know if its related or not, but my ac will blow cold at if my motor is cold butafter 10-15 mins of running down the highway ac starts blowing warm air. This didnt start until after i rplaced the pump aswell. Could a bad sensor cause this aswell? Thanks for the quick respose vwd
Does the compressor kick out after a while? I don't know if your blend door is cable, or funny little motor controlled.... Look under the dash, passenger side, just above the trans tunnel, if you see a little black box, about 3/4 inch thick, and about 2" by 2", heatertreater may be in your future. If you don't...... need to figger out what else is going on.
Try making sure your ECT is plugged in good. (You should only have the one.)
I just replaced the ECT today and the cable is hooked on good so I know its not that.
Just wondering if your problem was really just a loose cable.
Cause im stumped.............
