Timing gasket kit with or without sleeve?
Old Nov 29, 2011 | 11:31 AM
J415's Avatar
J415
Thanks for the follow up adrenaline and Hey You, thanks for the heart attack...jk
Old Nov 29, 2011 | 11:48 AM
gdstock's Avatar
gdstock
Originally Posted by adrenaline junky
Same seal in both kits. The sleeve is paper thin. You only have to use it if you have a groove in your shaft. For the couple dollars extra it's good insurance. You never know what you will find until you pull it off.
+1. I got the sleeve as I was accumulating parts for kegger mod and timing set for about a month before tearing it down. No way to tell if you need it until it is off unless you are leaking oil there, and not leaking oil does not gaurateee that there isn't a groove worn into pulley hub.
Measured seals and they were same size. You're good....
Old Feb 18, 2013 | 07:33 AM
NssJ's Avatar
NssJ
Do you need the $35 sleeve installation tool, or is there a cheaper/easier way?
http://www.jegs.com/i/Fel-Pro/375/16...oductId=762063
Old Feb 18, 2013 | 10:46 AM
Pull the balancer, and look at where the seal rides. If there isn't a groove there, you don't need the sleeve.
Old Feb 18, 2013 | 10:11 PM
dhvaughan's Avatar
dhvaughan
unless you have about a million miles, you won't have a groove nor need the sleeve.
Old Feb 21, 2013 | 06:49 AM
msheridan's Avatar
msheridan
I would personally use the sleeve, that stainless will outlive your truck and then-some.
I put the entire balancer in the freezer, and heated the sleeve in the oven. Next, using a wooden block (I used a piece of 2x4), I pressed it on and hammered the rest. I had zero issues, though, your success may vary. I wouldn't use a torch, you risk warping the sleeve because it is very thin.
Just because you don't "see" a groove, doesn't mean there isn't significant wear. It would suck having it all back together, only to find the front seal leaking days later. The sleeve is included for a reason, our balancers are known to wear, and subsequently, leak.
It's up to you.
