Timing gasket kit with or without sleeve?
Old Oct 10, 2011 | 01:53 AM
adrenaline junky's Avatar
adrenaline junky
Default Timing gasket kit with or without sleeve?
I have a 2001 w/5.9 and I'm replacing the timing set. I see that Felpro has 2 different kits available for their timing gasket.
FEL-PRO Part # TCS45996, w/o Sleeve 'N' Seal®; Must be used w/OS 34409R; PermaDryPlus® timing cover gskt. incl
FEL-PRO Part # TCS45999, Timing Cover Set w/Sleeve; w/Sleeve 'N' Seal®; Must be used w/OS 34409R; PermaDryPlus® timing cover gskt. incl.
Do I need the one with the sleeve and sleeve seal?
Old Oct 10, 2011 | 02:58 AM
candymancan's Avatar
candymancan
I just got this one for my Jeep with the 5.9
Worked fine Part No. TCS 45996 this is the $18 one without the sleev and seal
http://shop.advanceautoparts.com/web...010_1725992770____
Old Oct 10, 2011 | 07:25 AM
dhvaughan's Avatar
dhvaughan
you only need the sleeve if you have a horribly deep groove worn into the harmonic balancer's seal contact point. most people don't/
Old Oct 10, 2011 | 08:15 AM
aim4squirrels's Avatar
aim4squirrels
The sleeve goes on the harmonic balancer and gets locked down with a bit of loktite type goo. Don't mess with a sleeve unless you absolutely have to.
Old Oct 10, 2011 | 10:38 AM
adrenaline junky
That's what I was thinking about the groove. It's not leaking so I will probably go with the same kit that candymancan got. Since I'm getting most of my parts at rockauto, this gasket kit it's only $14.
Thanks guys!
Old Oct 10, 2011 | 11:09 AM
beeker's Avatar
beeker
I used the sleeve on mine. I didn't need it but I bought the kit with sleeve and was worried the seal might leak if I didn't use the sleeve with it. It works great.
Old Nov 28, 2011 | 09:42 PM
J415's Avatar
J415
So I just want to double check. I have the sleeve n seal kit and I'm ready to do the timing chain in the next week or two. The only reason to install the sleeve is if there's a groove on the harmonic seal contacting surface, correct?
Old Nov 28, 2011 | 11:45 PM
Correct. My personal preference is for the offset seal if there is a significant groove though.... Not sure if they are available for dodges.... haven't had to check.
I don't know if the seal that comes with the kit with the sleeve is larger inner diameter though, if it is, it may not seal well without the sleeve.
Old Nov 29, 2011 | 12:02 AM
J415's Avatar
J415
So wait, I might of screwed myself by getting the sleeve n seal kit? Would I be obligated to use the sleeve in order for the timing cover seal to fit right?
Old Nov 29, 2011 | 10:46 AM
adrenaline junky
Same seal in both kits. The sleeve is paper thin. You only have to use it if you have a groove in your shaft. For the couple dollars extra it's good insurance. You never know what you will find until you pull it off.
