new tranny and oil cooler
Old Oct 10, 2011 | 09:46 AM
DoubleL24's Avatar
DoubleL24
Default new tranny and oil cooler
I jus had my trany rebuilt and I put a heavy duty tranny cooler on. My question is how many qts of atf would I need to fill it. I have a 99 dodge ram 1500 4x4 5.9 gas auto tranny.
Old Oct 10, 2011 | 09:59 AM
zman17's Avatar
zman17
Retired Moderator - RIP
First page in FAQ section. https://dodgeforum.com/forum/2nd-gen...uid-types.html
Also Haynes manual page 1-2
Old Oct 10, 2011 | 10:08 AM
DoubleL24's Avatar
DoubleL24
Thanks zman cost me about $1500 for rebuilt tranny. Put a bigger oil cooler so hopefully won't have a problem.
Old Oct 10, 2011 | 10:22 AM
zman17's Avatar
zman17
Don't forget to use ATF+4. You should put a drain plug in the pan too, before you fill it.
Old Oct 10, 2011 | 10:59 AM
DoubleL24's Avatar
DoubleL24
Yea that's what I got but only have like 7qts gotta get some more usin castrol atf+4
Old Oct 12, 2011 | 08:51 PM
DoubleL24's Avatar
DoubleL24
It says 11.7qts to fill after rebuild does that fill the t-case to or do I need to put some in that to?
Old Oct 12, 2011 | 08:53 PM
TitanOneSeven's Avatar
TitanOneSeven
Transfer case is filled from a plug in the back of the case. It has it's own fluid supply.
Old Oct 12, 2011 | 08:55 PM
gdstock's Avatar
gdstock
Not sure about transfer case, but cooler may add an additional quart to capacity (depending on size).
Old Oct 12, 2011 | 08:56 PM
zman17's Avatar
zman17
Transfer case is separate, and will require the amount mentioned in that link. And just an FYI, depending on year and options, the tranny can take up to 16 gt's .
Old Oct 12, 2011 | 08:59 PM
DoubleL24's Avatar
DoubleL24
Ok its a 99 and so far I put 12qts in and seems good runnin it for a few days and keeping an eye on it.
