Question About Diff. Fluid
Old Oct 10, 2011 | 12:03 PM
zman17's Avatar
zman17
Retired Moderator - RIP
No problem B. And even if there is a question, you can just add a bottle of the stuff. It won't hurt anything if it's not lsd.
Old Oct 10, 2011 | 09:18 PM
Bob5151's Avatar
Bob5151
It turns out that I have an open diff. Are the fill holes on the actual cover? Because they are only about halfway up on the covers. So I would only be filling the diffs about halfway, is that correct?
Old Oct 10, 2011 | 10:24 PM
dhvaughan's Avatar
dhvaughan
^^ correct.
the easiest way is to just fill it until it begins to run out the fill hole.
2 - 2.5 quarts per axle is about right.
if you haven't bought your gear lube yet, walmart has it in gallon jugs for about $12. i think they have 85w90 and 75w140 (or maybe 85w140)
Old Oct 11, 2011 | 08:42 AM
Bob5151's Avatar
Bob5151
On the rear axle, it looks like it's a rubber plug. Does that just push out from the inside when I have to cover off, and then I can just push it back in?
And on the front, it looks like a square plug. Do I need a special wrench for this one?
Old Oct 11, 2011 | 08:44 AM
Rubber plug you can just pry out. It will push right back in.
Metal plug is threaded in.
Old Oct 11, 2011 | 02:09 PM
Bob5151's Avatar
Bob5151
I have 6 quarts of Pennzoil 75w-90 at home. Is that cool to use in the front axle, or do I have to use 75w-140?
Old Oct 11, 2011 | 05:27 PM
zman17's Avatar
zman17
The 75w-90 is fine.
Old Oct 11, 2011 | 06:02 PM
dhvaughan's Avatar
dhvaughan
just a normal open end wrench that fits. probably about 3/4 or so.
Old Oct 11, 2011 | 07:26 PM
Bob5151's Avatar
Bob5151
I'll probably be doing it this weekend. Thank you for the advice everyone, very much appreciated.
