Question About Diff. Fluid
Old Oct 10, 2011 | 09:51 AM
Bob5151's Avatar
Bob5151
Default Question About Diff. Fluid
Can I use Valvoline synthetic 75w-90 gear oil in my 9.25 rear and Dana 44 front axles without worry? I looked through the D-I-Y threads and didn't see this weight oil listed. I have some at home and would like to use it if I can.
Also, I see that I need 2.5 qts for the front axle, how much do I need for the rear? And can I use the same weight in both?
Any help would be appreciated!
Old Oct 10, 2011 | 09:55 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You'll be fine as long as you are not towing all the time. In that case I'd use 75w-140 and capacities and other info can be found in this thread in the FAQ section. https://dodgeforum.com/forum/2nd-gen...uid-types.html
Old Oct 10, 2011 | 10:01 AM
Bob5151's Avatar
Bob5151
Ok, I see that the D44 axle requires about 2.5 quarts. And am I reading it right that I should fill the rear axle to 5/8 of an inch below the fill hole?
chadhager03's Avatar
chadhager03
I think I used 5.2ish quarts total
Old Oct 10, 2011 | 10:30 AM
zman17's Avatar
zman17
4.8 pints for the rear diff. I don't know why it's not in there. And the 5/8ths is correct, but it's really not that big of deal.
Old Oct 10, 2011 | 10:34 AM
Bob5151's Avatar
Bob5151
So about 2.5 quarts for each axle. Thank you for your help guys.
Old Oct 10, 2011 | 10:37 AM
zman17's Avatar
zman17
You might want to make sure the rear diff is not an LSD. You'll need a small bottle of additive if it is an lsd. Then again, I think the synthetic comes with it already. Not sure on that though.
Old Oct 10, 2011 | 11:18 AM
Bob5151's Avatar
Bob5151
Yeah, I forgot about that. I plan on jacking up the rear tonight to check the back brakes anyway. How does it work, if I spin one wheel, and the other wheel spins the same direction, it's and LSD. And if the other wheel spins in the opposite direction, it's open, right?
Old Oct 10, 2011 | 11:28 AM
zman17's Avatar
zman17
I forget, lol sorry ( I think your right though). But you can look on the sticker on top of the radiator support, or there should be a sticker inside your glove box. It will say "anti-spin"
Old Oct 10, 2011 | 11:53 AM
Bob5151's Avatar
Bob5151
I'll take a look when I get home tonight (don't have the truck wth me at work). If that fails, I did request a build sheet today, so if I have to I'll just wait 'til I get that. Thanks a ton for the help.
