Knocking front axle, joint
Old Oct 10, 2011 | 11:24 AM
calumetbud's Avatar
calumetbud
Default Knocking front axle, joint
When I drive I hear a knocking metal sound from the drivers side wheel area.. I crawled underneath the truck and felt the u joint, it seemed to be all right, but the shaft going into the diff was loose knocking against the housing(tube). Is this the axle if so what does it take to replace it. Thanks
Old Oct 10, 2011 | 11:52 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I suggest you get a Haynes manual and download the service manual from the FAQ/DIY section. This will help also, but dont ignore getting the manuals. http://www.pavementsucks.com/tech-article-5.html
Old Oct 10, 2011 | 12:02 PM
calumetbud's Avatar
calumetbud
thanks will do..
Old Oct 10, 2011 | 12:09 PM
BigBlue83's Avatar
BigBlue83
I had this problem on my ram 1500 sport 98 the second day after i bought it it started. My u-joint was bad however it all came from the half axle shaft slidding in and out making the noise when we whent to put the axle shaft we realized the axle housing was bad and thats why the shaft kept slipping.
Old Oct 10, 2011 | 12:12 PM
calumetbud's Avatar
calumetbud
thanks for the input, is the ujoint all I need to replace..if the hubs are good..axle should be ok right..LOL hoping
Old Oct 10, 2011 | 01:05 PM
99dodge318's Avatar
99dodge318
Maybe a worn axle seal?
Old Oct 10, 2011 | 01:08 PM
zman17's Avatar
zman17
+1... If it's that bad, the seal is most likely damaged too.
Old Oct 10, 2011 | 01:38 PM
calumetbud's Avatar
calumetbud
geez, seal in the diff.?
Old Oct 10, 2011 | 01:43 PM
Unfortunately, yes.....
Old Oct 10, 2011 | 01:50 PM
calumetbud's Avatar
calumetbud
I think this repair is getting bigger than me..may have to call the pros..LOL Thanks guys
