Old Aug 6, 2015, 01:31 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
Brake and Reverse lights not working
Old Oct 10, 2011 | 10:25 PM
jbatir's Avatar
jbatir
Default Brake and Reverse lights not working
Hello,
This is my first post, I look forward to many more and learning more about my truck.
So, my truck was likely working fine all the way until this morning. Someone told me my brake lights weren't working.
Since then, I've checked the bulbs, no burnt filaments, It looks like the fuses are fine, although I just looked at them, didn't pull any out, and I keep seeing talk about relay switches, but nothing about brake and reverse lights only.
Can someone help me trouble shoot from here?
Thank you for any help you can provide, it is much appreciated!
Joe
Old Oct 10, 2011 | 10:29 PM
Grab the 01 service manual from the FAQ section, it will have wiring diagrams for you to check out.
Does your truck by any chance have the towing package? If it does, check where the trailer harness meets the rear light harness. (just follow it back.) They tend to sometimes cause issues.
'nother place to look is in the steering column, at the multifunction switch. Especially if you have tilt-wheel. The wires can get pulled out of the connector.
You may have two separate problems here. Fix the brake lites first, see if that doesn't solve the backup lights as well, if it doesn't.... well, we can take it from there.
Welcome to DF.
Old Oct 10, 2011 | 10:34 PM
crazzywolfie's Avatar
crazzywolfie
could also be a bad ground. all the lights in the back should share a ground connection.
Old Oct 11, 2011 | 07:00 AM
Lone136's Avatar
Lone136
I had the very same problem with my 01 sport. Take the back tail light out and have someone push the brakes for you and have a test light to check for power. I found that all my bulbs were good, but they weren't making contact in the socket. Also check the ground in the back of the truck
Old Oct 11, 2011 | 04:18 PM
jbatir's Avatar
jbatir
Thanks for the help so far.
It does have the towing package, I followed it back, nothing looks out of the ordinary, but I will likely replace the 5 pin fuse there just in case, it looks fine from the outside, but maybe not from the inside?
Since I have rear lights, turn signals, and hazards, can I rule out the ground for the back of the truck?
Also, question to show my immaturity with electrical issues, where exactly is the ground in the back?
Old Oct 19, 2011 | 12:17 PM
jbatir's Avatar
jbatir
Hey all, thanks for the help, I've got the brake lights working, it was a fuse in one of the relays, but I still don't have reverse lights. Any ideas?
Thanks!
Joe
Old Oct 19, 2011 | 12:18 PM
Check the neutral safety switch on the trans. Make sure the bulbs are good.....
Old Nov 4, 2011 | 11:58 AM
cfranr76's Avatar
cfranr76
1990 dodge dakota brake lights not working, but signal lights work, is there a fuse somewhere because I can't find one and switch is good ?
