Please help
Old Oct 13, 2011 | 07:57 PM
  #121
gdstock's Avatar
gdstock
I am officially and totally confused .... and need to know for sure as I plan to install modified kegger, timing set, water pump....etc next week.
This is in the FSM located here on DF.
What I am reading is different from this. Did this change with a particular year model?
Thanks.
Old Oct 13, 2011 | 08:15 PM
  #122
zman17's Avatar
zman17
Retired Moderator - RIP
Thanks.
NO, that's the way he should have done it to begin with. Very simple. But he didn't do that. Another example of how reading a Haynes or downloading and reading the free manuals in the FAQ section has bit some one.
On a side note, PLEASE READ THIS THREAD, https://dodgeforum.com/forum/2nd-gen...e-tragedy.html
Old Oct 13, 2011 | 08:31 PM
  #123
71dodge's Avatar
71dodge
all the intake push rods were bent. so my motor is not spinn free
Old Oct 13, 2011 | 10:15 PM
  #124
gdstock's Avatar
gdstock
OK. I feel less confused. What was throwing me is the postings stating both gears should be "12 o'clock" when it should be crank at 12 o'clock and cam at 6 o'clock. Been that way on every vehicle I have ever worked on (well, except the DOHC Jaguar - and that's a different beast).
It is kind of sobering to read posts here, knowing that VWandDodge and his family has suffered such a loss. I would like to encourage everyone in the DF to keep his family in their hearts and help with the efforts of drewactual and zman on our behalf. I only know of him from DF, but am greatly saddend by his loss.
Old Oct 13, 2011 | 10:18 PM
  #125
gdstock's Avatar
gdstock
I wonder if valves are bent as well, allowing each cylinder to be open. May require pulling heads to be sure, and to be sure that a piston did not get damaged by slapping a valve or three....
Old Oct 13, 2011 | 10:27 PM
  #126
CPTAFW163's Avatar
CPTAFW163
But this thread you posted from moparchat said to do 12/12 not 6/12.
http://www.moparchat.com/forums/showthread.php?t=96310
But yes, if you do work, go to autozone and spend the 20 bucks on the haynes manual. I have a HAYNES, CHILTONS and the FSM.
Old Oct 13, 2011 | 11:26 PM
  #127
71dodge's Avatar
71dodge
im hoping it didnt bend any valves because the motor didnt crank over long enough to do any damage except the pushrods
Old Oct 14, 2011 | 08:21 AM
  #128
71dodge's Avatar
71dodge
im getting push rods today and we will see if it runs right. and im setting the timing at 6 and 12. not 12 and 12
Old Oct 14, 2011 | 05:08 PM
  #129
71dodge's Avatar
71dodge
well i bent some valves. heads are coming off now. oh well
Old Oct 14, 2011 | 05:57 PM
  #130
zman17's Avatar
zman17
That's only because the first few guys that posted were/are wrong.
