Please help
Old Oct 12, 2011 | 11:52 PM
  #71
71dodge's Avatar
71dodge
Originally Posted by CPTAFW163
WAIT WAIT WAIT.
you don;t need to rotate ANYTHING after you get to TDC because the crank and cam are already lined up. You just need to reinstall the crank and cam sprokets 12 oclock and 12 oclock. THEN make sure the pulley/dampener is INSTALLED at TDC on the timing cover.
If you ahve not pulled the dist, then you don;t need to degree the camshaft or rotate it.
If you rotated the camshaft once you got the crank to TDC, then you will be on a wild goosechase
i turned the cam withe the gear on it to turn the rotor in the distributor.? and then after that i had the crank at TDC i thought and i still got nothing
Old Oct 12, 2011 | 11:54 PM
  #72
CPTAFW163's Avatar
CPTAFW163
Originally Posted by 71dodge
oh okay so basicly wen the vavles are closed thats TDC. now when i put the balcener on and align it to the TC cover then it will be trueTDC and the valves will still remain closed but the piston will have moved up the extra 1/8th of a inch to meet the TC mark?
When ONLY the intake valve is closed.
Answer this question:
When you were doing any of this, did you rotate your camshaft when your timing chain was not on the cam AND crank sprokets?
Old Oct 12, 2011 | 11:55 PM
  #73
71dodge's Avatar
71dodge
yea i did to get the rotor to the #1 plug wire but other then that no
  #74
CPTAFW163's Avatar
CPTAFW163
I know the gear was on it, but was the CHAIN on it.
Old Oct 12, 2011 | 11:56 PM
  #75
71dodge's Avatar
71dodge
no the chain wasnt on it
Old Oct 12, 2011 | 11:57 PM
  #76
CPTAFW163's Avatar
CPTAFW163
OK, that is the problem. If you turn the cam, then your intake valve will NOT be closed! You are moving the valvetrain.
Since you said you did not take out the distributor, you should have the rotor pointing to #1 when you are at TDC.
Did the cam slide out at all then you needed to put it back in?
Old Oct 12, 2011 | 11:58 PM
  #77
CPTAFW163's Avatar
CPTAFW163
BINGO, read my earlier post.
Basically you are getting the piston to TDC but not the valves.
Old Oct 12, 2011 | 11:59 PM
  #78
CPTAFW163's Avatar
CPTAFW163
Here is what to do, wait for editing....
With the chain OFF:
1. Rotate crank until the piston is at the top.
2. Rotate the cam until the intake valve is fully closed, the rotor should be pointed to the #1 cylinder on the distributor.
3. Take off the sprockets and REINSTALL them at 12 oclock and 12 oclock Do NOT rotate the engine to do that.
4. Install the chain and timing cover
5. Install the balancer/pulley lined up with the TDC mark on THEM and the Timing cover.
It should fire up. The reason it was not firing and you had no compression was that you were changing the valve position (open closed) when rotating the camshaft to line up the doots when all you needed to do was REINSTALL the sprocket in that 12/12 oclock position (assuming you were at TDC when this all started). When doing the timing chain, you just install and reinstall the sporckets in the SAME POSITION as you started. People usually put the engine at TDC before they do the swap.
If Step 2 does not yield the rotor pointing to #1, then something is wrong and you might need to pull the distributor. But only do that as a last resort and wait for someone other than me to chime in.
  #79
71dodge's Avatar
71dodge
i turned the cam to get the rotor to TDC. and the cam did not slide out at all. now that i screwed it up how do i get the vavle to close back up
Old Oct 13, 2011 | 12:00 AM
  #80
merc225hp's Avatar
merc225hp
Ok basics 101
1:The intake stroke is, intake valve is open and the piston is in a down stroke
2:comp stroke both valves closed piston moving up, spark is added at tdc
3 power stroke ign and the piston is moving down, both valves closed
4:exhaust stroke, exhaust valve is open and piston is moving up.
