Won´t get really warm..?
Old Oct 13, 2011 | 04:11 PM
Stoft's Avatar
Stoft
Default Won´t get really warm..?
Hello!
My 97 Ram 1500 5.2 4x4 only gets like 70 degrees warm.
What can the problem be? Thermostat?
Is it hard to change?
Old Oct 13, 2011 | 04:15 PM
kadetklapp's Avatar
kadetklapp
Engine temp, heater temp? Which is it? What are you referring to specifically?
Old Oct 13, 2011 | 04:24 PM
Matt Nickerson's Avatar
Matt Nickerson
Most likely a stuck open thermostat.
Not sure what else could cause it...bad temp gauge? 70* is a little low.
http://www.youtube.com/watch?v=RIC6Z4D6Q3E
Old Oct 13, 2011 | 07:41 PM
will4557's Avatar
will4557
Mine was running cool to and I had a stuck open t-stat. I replaced it (wasnt hard at all) and now it is running the correct temp and the heater warms up like it is supposed to.
Old Oct 13, 2011 | 09:11 PM
SilverSS's Avatar
SilverSS
I would check the gauge first and make sure it's accurate. Is the heat hot? Does the transmission lock up in OD?
Old Oct 13, 2011 | 10:51 PM
gdstock's Avatar
gdstock
If it is a fail safe tstat (and fails correctly) it will allegedly fail open, not allowing temp to rise. Can't believe the cooling system is that efficient. If mine ran 70 I wouldn't have to run AC!
Old Oct 14, 2011 | 12:16 AM
Stoft's Avatar
Stoft
it locks up in OD. it doesnt blow really hot as it should and it takes a long time for the engine to get hot (around 70)
Old Oct 14, 2011 | 12:34 AM
Hahns5.2's Avatar
Hahns5.2
If the TC is locking up, the coolant is getting to at least 140º. Or are you talking Celsius? In that case 70ºC is 158ºF, which is still too cold. Replace thermostat and go from there.
Old Oct 14, 2011 | 11:12 AM
Stoft's Avatar
Stoft
Yes 70ºC.
http://i56.tinypic.com/smrkvm.jpg
Old Oct 14, 2011 | 05:38 PM
John D in CT's Avatar
John D in CT
For the non-Socialists here, 70 C. is 158 F.
