Installed new transmission, now NO BUS
Old Oct 14, 2011 | 06:58 PM
XxCutterxX's Avatar
XxCutterxX
Thanks guys, it is much appreciated. I will go back thru the wiring for the PCM and tranny.
Old Oct 14, 2011 | 07:04 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by XxCutterxX
Would crank sensor give a no bus?
It is possible if the wires are pinched. Just make sure , that's all I'm saying. Get a mirror and look back there. Of course it most likely wouldn't run too good either. There are a bunch of threads about no bus( I don't recall the fixes at the moment), your problem could be totally unrelated to the tranny swap. I'm just thinking tranny swap related issues.
Old Oct 14, 2011 | 08:30 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
I bought a truck that had been tip on its side. The owners pulled the transmission before I bought it. A newer transmission was put in it, but getting a "no bus" code. It shifts fine runs fine but have the code. Has me stumped. What do you guys know of the no bus code?
Reading "No Bus" on the cluster? Or do you have an actual P code you can post?
Old Oct 14, 2011 | 10:02 PM
No bus means the cluster isn't hearing anything from the PCM. That's either a bad connection somewhere, bad central timer module, or failing cluster. Do any of the gauges work?
Old Oct 15, 2011 | 06:57 AM
Novarider's Avatar
Novarider
Will a pinched crank sensor wire cause a no bus issue? I ask because my no bus problem started after I had the tranny rebuilt.
Old Oct 15, 2011 | 08:01 AM
mrfarrell's Avatar
mrfarrell
yes it will but normally that could cause a no start situation..no bus means theres an issue in the can data bus system..somethings not communicating with something else probly something as simple as a loose connection or bad ground.
Old Oct 15, 2011 | 11:31 AM
badmojo's Avatar
badmojo
Default no bus
New guy here. I had the same 'no bus' issue a couple a years ago with my 01 5.9 , What i did was disconnect 1 connector at the pcm (there should be three, i started with the left one first then i did the right) then crank the engine, reconnect and and start the engine, check and see if fixed, if not do the the same with other connector. Hope this helps you out.
Old Oct 16, 2011 | 02:47 PM
XxCutterxX's Avatar
XxCutterxX
No "P"codes. Just "no bus." Checked the grounds and pinched wires. All seems to be in order. The fuel gauge is the only gauge not working. Tried the disconnects on the pcm and nothing changed. The truck sometimes turns over a few times after the key switch is off. The check engine light and abs and brake lights are on.
Old Oct 17, 2011 | 02:20 PM
mrfarrell's Avatar
mrfarrell
so the engine wont even crank over?
Old Oct 17, 2011 | 02:54 PM
Novarider's Avatar
Novarider
I have a question about my no bus problem. My gauges will die and I get no bus in the mileage window. When this happens if I push on the cluster or smack the bezel right below the cluster the gauges come back on. They will go out in a minute or so then I smack it and they come back again. Does this sound like a bad cluster?
