Installed new transmission, now NO BUS
Old Oct 14, 2011 | 04:23 PM
XxCutterxX's Avatar
XxCutterxX
Question Installed new transmission, now NO BUS
I bought a truck that had been tip on its side. The owners pulled the transmission before I bought it. A newer transmission was put in it, but getting a "no bus" code. It shifts fine runs fine but have the code. Has me stumped. What do you guys know of the no bus code?
Old Oct 14, 2011 | 05:49 PM
zman17's Avatar
zman17
Retired Moderator - RIP
All the ground wires look good? Also check and make sure the crank sensor wire is not pinched between the motor and tranny.
Old Oct 14, 2011 | 06:13 PM
71dodge's Avatar
71dodge
wouldnt the wrong valves body do that as well?
Old Oct 14, 2011 | 06:21 PM
zman17's Avatar
zman17
I don't think so, But it would be nice if XxCutterxX , put all the info about his truck in his sig, and profile if he posts using a cell phone.
Old Oct 14, 2011 | 06:36 PM
71dodge's Avatar
71dodge
what years the truck and what years the tranny?
Old Oct 14, 2011 | 06:39 PM
zman17's Avatar
zman17
What you are talking about is the solenoids. Even if they are wrong for the year, it will not cause a "no bus" . All that will do is, is prevent the the tranny from shifting into OD.
Old Oct 14, 2011 | 06:41 PM
71dodge's Avatar
71dodge
bad crank sensor?
Old Oct 14, 2011 | 06:43 PM
XxCutterxX's Avatar
XxCutterxX
Sorry guys new to the forums, Still trying to find my way around here.
The truck is a 2001 ram 1500 360. The transmission is a 2002. Or so I was told. Have check the grounds and all looks good there. The wires from what I can see are all clear as well. Could it be the solenoid in side the valve body?
Old Oct 14, 2011 | 06:46 PM
XxCutterxX's Avatar
XxCutterxX
Would crank sensor give a no bus?
Old Oct 14, 2011 | 06:54 PM
gdstock's Avatar
gdstock
I would think a bus error would relate to PCM. Check connectors and make sure they are secure.
The solenoid would only prevent proper shifting - nothing more.
