*Help* knocking and failure to shift!
Old Oct 17, 2011 | 09:28 AM
decovision's Avatar
decovision
Unhappy *Help* knocking and failure to shift!
I just purchased a used, one owner 1998 Dodge Ram 1500 5.9l 4x4. When I initially start the truck and right before it shifts into 2nd gear, it does a knocking rattling sound and it wont shift into gear unless i let off the gas, it doesnt do it as much when the truck is still cold or the o/d is off.
Ive been told it is some kinda sensor. but I dont know, havent ran codes yet...
Also, unrelated, the oil pressure gage drops to 0 when i come to a stop. but then shoots back up to normal when i take off. somethings itll drop even when driving. Sensor as well??? which one?
I would appreciate the help...
Old Oct 17, 2011 | 09:32 AM
If the CEL is on, need to know what the codes are.
For the oil pressure, check your oil level..... sounds like you are low.
Old Oct 17, 2011 | 05:44 PM
zman17's Avatar
zman17
Retired Moderator - RIP
For the tranny, it's most likely the Governor pressure switch and Governor solenoid that needs replace.
Old Oct 17, 2011 | 05:59 PM
BackwoodsRam's Avatar
BackwoodsRam
you could try a tv cable adjustment, those things outta wack can cause some wierd problems
Old Oct 20, 2011 | 10:06 AM
decovision's Avatar
decovision
thanks ya'll first Ill go get the codes checked. and after that, process of elimination. thanks for all your help!
Old Oct 20, 2011 | 11:57 AM
zman17's Avatar
zman17
You can try this to read the code's yourself. But most likely won't work on a 98.
https://dodgeforum.com/forum/2nd-gen...code-list.html
