steering still stuck
Old Oct 17, 2011 | 10:47 PM
BackwoodsRam's Avatar
BackwoodsRam
+1 on the pump, i recently replace my gearbox and had to turnaround and replace the pump 2. I dont know why i didnt suggest it
mrfarrell's Avatar
mrfarrell
so when you jack up the front everything moves easily and when you lower it down it binds?
Old Oct 17, 2011 | 10:48 PM
sam_priem's Avatar
sam_priem
Originally Posted by John D in CT
"i figured if the pump was bad then fluid wouldnt be moving through the lines".
A functioning power steering pump puts out 1,000+ PSI. Fluid will move through the lines at 1 PSI. Simple enough to test how much pressure it's putting out.
so if its just pushing out a small stream its bad? or should it be shooting out with some pretty good force?
Old Oct 17, 2011 | 10:52 PM
John D in CT's Avatar
John D in CT
It's more about the pressure it puts out when it's called on to do so; sure, it has to flow x amount of fluid per x amount of time, but when you open the high pressure side the pump can't really build up any pressure, so a bad one might seem to flow as much as a good one. That's why you need to test it with a gauge that can offer resistance.
(And again - was it acting this way before you replaced the steering box?)
"so when you jack up the front everything moves easily and when you lower it down it binds?"
I think the jury is still out on whether or not anything is binding; I just don't think the pump has enough *** to move the wheels when they're on the ground.
Old Oct 17, 2011 | 11:03 PM
sam_priem's Avatar
sam_priem
thats what im thinking but ive driven vehicles without power steering and once youre going about 45 or so its easy to steer. however with mine it doesnt matter how fast im moving its the same all the time. its equaly as hard to turn at a stand still as it is moving. thats whats confusing me.
Old Oct 17, 2011 | 11:17 PM
John D in CT
From my experience, vehicles with power steering that have lost the "power" part are ten times harder to turn than vehicles with manual steering, whether you're going 5 MPH or 50.
And at the risk of being annoying: was it acting this way before you replaced the steering box?
(And is the belt on?)
Old Oct 17, 2011 | 11:23 PM
sam_priem's Avatar
sam_priem
yes it was acting this way before i put the steering gear in. and yes the belt is on.
Old Oct 17, 2011 | 11:24 PM
EndIsNear's Avatar
EndIsNear
My bet is on the pump as well. It can move fluid, but it may not pressure up enough, as stayed before. Did you try bleeding the system? It could be air in the steering box or pump.
Old Oct 17, 2011 | 11:27 PM
Jack up the front of the truck, unlock the steering, do not start the motor. Turn the wheel. How much effort does it take? Ok, now, start the engine, turn the wheel. Same amount of effort? Replace the pump.
How did you go about bleeding the air out of the system?
Old Oct 17, 2011 | 11:33 PM
BackwoodsRam
the OP's problem started in another post guys. he hit a bump and steering locked up. he took off his draglink and column and found the gear box was locked up
