power steering pump?
Old Oct 18, 2011 | 04:07 PM
sam_priem's Avatar
sam_priem
Default power steering pump?
anyone know how to get the pump out of the reservoir? auto store has just the pump and the pump with reservoir on it. i want to get the pump out so i dont have to spend extra money on the reservoir.
Old Oct 18, 2011 | 04:10 PM
Just a couple bolts on the back side of the tank, also need to pull the flow control valve. (the part the pressure hose screws into.)
I have NEVER had any success replacing just the pump, on vehicles that had the pump in the reservoir, it ALWAYS leaked around the pump face to housing interface. There's gotta be some trick to making that work, but, I sure don't know it.
Old Oct 18, 2011 | 05:54 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Doesn't VWandDodge have a DIY on this, in the FAQ/DIY section?
Old Oct 18, 2011 | 06:21 PM
Hans_GZP's Avatar
Hans_GZP
I bit the bullet and spent the $65 on a pump with reservoir on it. It's not worth the headache. Kinda like trying to rebuild your steering gear box.
Old Oct 18, 2011 | 06:43 PM
John D in CT's Avatar
John D in CT
He sure does; quite a write-up, with 8 x 10 glossies with circles and arrows on the back of each one. (Born after 1965? Disregard that).
He does the whole pump rebuild, but shows how the reservoir comes off and goes back on, with a new O-ring and some vaseline he just happened to have lying around.
I've swapped reservoirs at least once, maybe twice, and it's never been a problem getting a good seal. Just have to make sure the mating surfaces on the reservoir are nice and straight, and fit snugly against the o-ring. I can see saving a few bucks by swapping reservoirs, if the old one is in decent shape. Not sure if I'd bother rebuilding the pump, but as I just let on, I'm old.
Old Oct 18, 2011 | 07:57 PM
zman17's Avatar
zman17
I know, just being sarcastic. LOL
Old Oct 18, 2011 | 08:01 PM
John D in CT
Well how was I supposed to know that? That's the last thing I would have expected from you.
