"95" 5.9 hesitates
Old Oct 27, 2011 | 07:05 AM
mr wendy's Avatar
mr wendy
Well did complete tune up Battery good...new pcm...everything helps a little..Starts good runs great on the road ( short trips)..But dies when coming to a stop...Keep it running with gas pedal and it goes back to normal idle after stopping....Is there a sensor on the trans conected to idle.....
Thanks for all the help....
Old Oct 28, 2011 | 01:03 AM
Wombat Ranger's Avatar
Wombat Ranger
This happened to me when my front driveshaft ate through my speedometer sensor wire. had the same symptom after i just disconnected it. fixed wires, plugged er back in, haven't had any issues since. Hope this helps.
Old Oct 28, 2011 | 12:23 PM
mr wendy's Avatar
mr wendy
Ok thanks I'll check it out.....
Old Oct 28, 2011 | 12:47 PM
zman17's Avatar
zman17
Retired Moderator - RIP
So did you replace the IAC and or crank sensor?
Old Oct 28, 2011 | 02:59 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
What about the TV cable on the TB? Would that have any affect? If you drop it into neutral at a stop light, does it actually idle on its own?
Old Oct 28, 2011 | 03:50 PM
peshewa's Avatar
peshewa
I would think that if a sensor was causing this issue, there would be a code on the reader displaying it. Part of me wants to say clean all the cables at both ends for positive connection just in case of a bad ground, but I think you said you did that already. If I had something that acted like a vacuum issue that I could not track down by replacing vacuum lines, I would start & idle the engine, then get a handheld propane torch, turned on but not ignited, slowly move it around the intake and see if the idle speed changes when you think it would not. The same test can be done with a can of carb/brake parts cleaner, but is a little more dangerous. This can help identify any strange vacuum leaks. Keep us posted!
Old Oct 28, 2011 | 03:57 PM
Carb cleaner/brake clean isn't nearly so flammable as it once was......
Old Oct 28, 2011 | 04:09 PM
zman17's Avatar
zman17
The TV cable has nothing to do with it. All it does is change pressure for shifting.
Old Oct 30, 2011 | 09:56 AM
mr wendy's Avatar
mr wendy
Thanks for all the help...I think I actually had 2 problems at the same time...The hesitation and stalling on acceraltion are fixed...Now it runs great just idles wierd...Sitting still it has a lope to it like its cammed up...let off the gas coming to a stop and idle goes to 100/200 until completly stopped then in a few seconds levels of to normal. Stopped on a hill yesterday put it in neutral and let the truck roll never touched the gas.At about 5 mph the idle went to 100/200..... stopped and it went back to normal...I'm completely lost on this on thanks again to everybody for all the help.....
Gonna check out the speed sensor today....
Old Oct 30, 2011 | 01:56 PM
grox's Avatar
grox
What fixed the hesitation and stalling?
