what should i get for sway bar connects?
Old Oct 23, 2011 | 02:35 PM
brian_87's Avatar
brian_87
Talking what should i get for sway bar connects?
hey guys i just did a 3 inch leveling lift kit in my 98 2500 4x4 and the kit didnt come with sway bar connects ive tried to find some cheep ones but havent had any luck anyone know of a good site to get them from thanks.Brian
Old Oct 23, 2011 | 02:43 PM
zman17's Avatar
zman17
Retired Moderator - RIP
That's because for a 3" lift you don't need to do anything with the sway/ stabilizer bar.
Old Oct 23, 2011 | 03:17 PM
brian_87's Avatar
brian_87
ya i still wanna beef them up the ones that were on it were snapped both sides i do 4by alot so i need to upgrade
Old Oct 23, 2011 | 05:49 PM
IF you off road a lot, and you can live without the sway bar, leave 'em broke. Better flex that way.
Old Oct 23, 2011 | 08:08 PM
BackwoodsRam's Avatar
BackwoodsRam
I took my swaybar off about a year ago. Handling hasnt sufferd very much.
Old Oct 23, 2011 | 08:17 PM
dsertdog56's Avatar
dsertdog56
If you drive on the highway, tow, or deal with crosswinds, fix 'em before you kill someone. I utilized warrior disconnects off a Cherokee, but Top Gun Customz, Kore, and others offer them as well.
You can always pull the disconnects to off road for low speed flex.
Since you have a 2500, you may be able to use the disco's for a 5 inch lift...your truck is about 5 inches over a 1500 now. I believe a '98 is a stud mount on both ends right? If so, wrangler disco's might work.
You'll want to get the right length, so use a tape measure and make sure your sway bar is high enough so the length of the disconnect makes it parallel with the front coil spring. That way any force from the bar is applied directly into the body to decrease roll.
Old Oct 24, 2011 | 12:19 PM
brian_87's Avatar
brian_87
ya but can the coils pop out with alot of flex with out the connects
Old Oct 24, 2011 | 12:28 PM
brian_87's Avatar
brian_87
i found these on ebay there not disconnects but oh well ill just carry a couple wrenchs with me no biggie
http://www.ebay.com/itm/330558980239...84.m1423.l2648
Old Oct 24, 2011 | 12:34 PM
BackwoodsRam
your links would break long before your coils would pop out, thats why rock crawlers dont use them. they severly limit flex
Old Oct 24, 2011 | 12:38 PM
brian_87's Avatar
brian_87
no i mean with out the connects but i just ordered the ones i found on ebay. im going to see if i can make them into disconnects
