Basic O2 Question
Old Oct 23, 2011 | 05:34 PM
wyomingdodge7's Avatar
wyomingdodge7
Default Basic O2 Question
Hey everyone, sorry for such a simple question, but I was going to replace the o2 sensor today and just wanted to make sure I wasn't going to accidentally do something catastrophically wrong. I searched for this topic but couldn't quite find the answer I was looking for.
It appears that you just unscrew the old and screw in the new, at the same time just unplugging and plugging in the new one... is it this easy?
Second, I heard I should reset the PCM? Is this a good idea, and if so, how do you do that?
Thanks again from Wyo
Old Oct 23, 2011 | 05:43 PM
Well, I don't know if I would classify it as "easy".... consider it IS exhaust work.... and the O2 sensors can sometimes be a real bear to get out, but, aside from that, yep. It really is just that easy.
Get a Denso, or NTK O2 sensor, stay away from the Bosch units. They don't work so good.
To reset the PCM, just disconnect the battery for a few minutes. Yes, you DO want to do that, so the computer can re-learn to run the engine, with the new sensors. It's important to do so.
Old Oct 23, 2011 | 06:04 PM
gdstock's Avatar
gdstock
Yes to your first question It may be pretty tight.
Also, before you remove it, disconnect battery. When you get O2 sensor back in and connected, then connect battery back. This will reset PCM.
Old Oct 23, 2011 | 06:22 PM
wyomingdodge7
I can't get the electrical clip off Is there a trick to this? Its super hard to reach and I can't seem to get it off....
Old Oct 23, 2011 | 06:26 PM
There is a lock tab you have to lift up a bit, and then pull the connectors apart. And yes, they REALLY put that in an awkward position.
Old Oct 23, 2011 | 07:54 PM
wyomingdodge7
Got it!! Finally!! Thanks guys
Old Oct 23, 2011 | 10:07 PM
lastrights's Avatar
lastrights
suck man lol need viagra ?
Old Oct 24, 2011 | 01:24 AM
wyomingdodge7
^^ hahahahahahahahahah it took me almost 2 hours!
