What is this that I found in my tranny pan? (pic)
Old Oct 23, 2011 | 08:01 PM
DukesOfHazzard's Avatar
DukesOfHazzard
Default What is this that I found in my tranny pan? (pic)
It was stuck to my magnet , mag had reg small buildup like usual fluid clean, was doing filter and fluid change and found this , kinda looks like a piece of large snap ring or kinda like a piece of piston ring it has discoloration liked its been heated (blue purpleish color) and how screwed am I?
Old Oct 23, 2011 | 08:05 PM
gdstock's Avatar
gdstock
Looks like snap ring. Very. Time for a rebuild.
Old Oct 23, 2011 | 08:28 PM
Yeah, what he said. At the very least, rebuild the O/D unit.
Old Oct 23, 2011 | 09:00 PM
Mikester1's Avatar
Mikester1
Possible piece from the planatary gear? Either way that should not be in there. Re-build.
Old Oct 23, 2011 | 09:12 PM
John D in CT's Avatar
John D in CT
OK, I'll be your one little ray of potential sunshine. I think it can be said that it's possible that if that is from a snap ring, that the rest of it is still in place. If not, wouldn't you see a broken snap ring, or parts of one, floating around somewhere in your tranny case? You should be able to see in there pretty well with the cover off. Or maybe it's a little chunk off of a gear that still works OK.
And is the tranny giving you any trouble? I know these guys are eager to rip Two Large out of your wallet, but maybe just button it up and run it, being prepared to rebuild it at the first sign of actual trouble. And who knows; if doctors can leave sponges inside patients, maybe it's been in there since your tranny was manufactured.
Old Oct 23, 2011 | 09:19 PM
gdstock's Avatar
gdstock
I'm not anxious to rip anything out of anyone's wallet. Mine was about $600 with upgraded parts and me doing the labor. But I had to pull it twice to get it right. I cannot advise to let it go until problems arise, as any damage caused would be more catastrophic - hence costing more to rebuild.
If you are up to the challenge, download the service manual and do the work yourself. Several good threads on here to help out.
If you weren't having problems, replacing snap ring or wahtever the piece is from may take care of it.
Old Oct 23, 2011 | 09:25 PM
DukesOfHazzard
no problems as of yet.It was'nt in thier before when i changed the oil ,and saw no other pieces, put the filter and +4 fluid back in and hope for the worst and told the old lady to keep her phone on thanks guys not much i can do, so might as well drive it into the ground and buy the viper tranny when it goes. 138,000 miles
Old Oct 23, 2011 | 09:31 PM
John D in CT
Yeah, sorry about implying that anyone really wants to waste the OP's money, but ... I'm still inclined to say that if there were no problems, and continue to be no problems, I'd run with it until the very first sign of an odd noise or driveability issue - especially if there's nothing out of the ordinary to be seen inside the case.
That's a pretty small piece of metal after all. And OP, are you going to take the truck immediately out of service, or run it a little and see what happens?
Old Oct 23, 2011 | 09:32 PM
Adobedude's Avatar
Adobedude
Reality is...OD snap ring. Re build time. But yeah, he can run it as long as he a good pair of walking shoes or AAA to come get him when it quits working.
EDIT: I've seen that part in two 46REs, and they both quit working...It's not a matter of if, but when.
Old Oct 23, 2011 | 09:34 PM
UnregisteredUser's Avatar
UnregisteredUser
Sounds like a good plan to me. As soon as my 3-OD shift got sloppy I called PATC so I could avoid unscheduled downtime.
My guess is that the snap ring piece came from the overdrive unit and it's just a matter of time before it fills the rest of the machine with shredded metal... so you might just want to spring for a remote filter now to save the cooler from that fate.
