What to look for when purchasing 2nd Gen Ram?
Old Oct 25, 2011 | 09:48 PM
  #21
chadhager03's Avatar
chadhager03
Make sure the tires and transmission shift really well, those two alone will set you back 2500+ dollars, if I would have known how much tires were I wouldnt have bought my truck. Dash board is about 400 +- which isnt bad, and I haven't had to replace anything else. Well I'm going to do the plenum and everything else which should be in the $400 range for all new everything that's important to get good gas mileage and stock power back. But you'd probably have to do that to any truck.
Old Oct 25, 2011 | 10:04 PM
  #22
Magnum4406's Avatar
Magnum4406
I have just over 180k on my original trans and engine. The problem I see most often is running overdrive in the city. I know mine doesn't hardly ever get to torque converter lockup in city driving....no lock up, more heat! Also accelerating it wants to drop to 3rd...more shifts = more wear and heat. I have a shift kit in mine..firmer shifts means less slippage and heat. I do use overdrive on the highway, usually over 60mph or so. That way it stays in od and the converter locks up. I change the fluid and adjust the bands every year or so..and I don't baby it! 95 1500 4X4 318. Plenum doesn't leak yet either! My complaint is rust..doors, rockers, etc. Michigan salt http://youtu.be/Yfvy2JY4Nx8
