That gadget ain't no magic bullet.. it does, eh, on its own.. it shines when it pulls the supporting mods together.. drop in some 1.7's, or open up the exhaust.. or both.. both, after a permanent plenum fix that is.. put the tune that best supports whatever gas you have in the tank on it, run it half way hard.. pull over, get a burger or something.. the get back in the truck, load the stock tune, and see if you can make it all the way home without pulling over to reload the hot tune again..
I just got my SCT from Hemifever too, been running it a few days on the 93 tune. I did notice a big improvement. Has more punch on the throttle and the shifting is much improved.
Ofcourse my truck was detuned from the factory with deathflash so I'm sure that is a big reason I notice more improvement than yours.
You get any ping with the 93 tune? Guess I need to start doing some mods but my wallet is a little light right now, I spent over $1,000 in the past month on my truck
