Grade 8 or Torque-to-yield for intake manifold and plenum?
Old Oct 26, 2011 | 04:58 PM
stewie01's Avatar
stewie01
Originally Posted by 99dodge318
I just went to the dealership and got them for like $16. And theres a tiny "m" stamped on the top! Lol
So if you go to the dealership and buy a set of bolts (for intake and plenum) what kind are you taking home? TTY?
Old Oct 26, 2011 | 04:59 PM
Don't get the plenum bolts from the dealer, they come with the plate, no matter which one you get. Intake to engine bolts are TTY though. THOSE are found at the dealer, and surprisingly enough, cheaper than most other places.
Old Oct 26, 2011 | 08:09 PM
J415's Avatar
J415
If you go the "grade 8" route, MAKE DAMN SURE YOU CLEAN ALL THREAD MATING SURFACES!!! If not, the thread locker is useless.
Old Oct 26, 2011 | 08:32 PM
Adobedude's Avatar
Adobedude
Well...
I use Stainless Steel allen bolts from Home Depot, never had a problem with numerous manifold installs, never used any thread locker, (why?) and don't understand the need for grade 8 bolts on 12 ft lb torque rating...?
Old Oct 26, 2011 | 09:01 PM
Hahns5.2's Avatar
Hahns5.2
I reused the stockers I let you know when my truck explodes
Old Oct 26, 2011 | 09:13 PM
grox's Avatar
grox
This is an awesome description of bolt tightening theory: http://www.enginebuildermag.com/Arti...uetoangle.aspx
Old Oct 26, 2011 | 09:58 PM
Adobedude's Avatar
Adobedude
What...You did not buy into the Chrysler TTY bolt Hype/crap?
Old Oct 26, 2011 | 10:28 PM
aim4squirrels's Avatar
aim4squirrels
I use stainless. Every time I took the manifold off with either grade 5 or the stock bolts the things were corroded as all get out. I'll wager that blow by gases and electrolysis work a double whammy on them.
There are several charts on the Web with torque values for various bolts. IMO, the best bolt to use would be the one that gets as close to 144 in/lbs as possible at the correct torque yield.
Stainless is close. Monel bolts would be best, but its damn pricey for the corrosion resistance characteristics.
Be careful what you buy at the local hardware store. If you buy a 2.25" grade 5, because you are trying to match the length of the factory bolt, you might find that they run out of thread before you get adequate clamping force on the gasket. On the other hand, the 2" bolts only grab by a few threads. A 2.25" all thread bolt would be best.
Old Oct 26, 2011 | 11:03 PM
grox's Avatar
grox
Is a thread locker recommended with the factory bolts?
Old Oct 26, 2011 | 11:52 PM
I didn't use any, and the various manuals didn't call for it either.
