damn had to drill bumper
Old Jul 27, 2005 | 04:57 PM
Tani1500's Avatar
Tani1500
Default damn had to drill bumper
this sucks, i had to drill my crome bumper to put on the License plate since theres only 2 holes on the bottom and none on the top. I hated to do it but it looked like crap and i was sick of hearing it rattle.
Old Jul 28, 2005 | 12:38 AM
theshocker's Avatar
theshocker
Default RE: damn had to drill bumper
Thats a shame man. When these bumpers are cleaned and polished thay look too damn good for a lisence plate.[sm=imsorry.gif]
Old Jul 28, 2005 | 01:11 AM
2kramquad's Avatar
2kramquad
I did the same thing to mine in lieu of spending $25 for a tag holder from the dealer. Drilled and tapped the holes, works good, looks better than either having the top of the tag flopping or hanging down below.
Old Jul 28, 2005 | 01:25 AM
4DrMopar's Avatar
4DrMopar
I hung mine down,and put my DIVER /FD tag on top.... its a halftag
Old Jul 28, 2005 | 01:10 PM
greenmachine's Avatar
greenmachine
just an idea but you could have glued a small piece of foam or rubber to the back of the plate.
Old Jul 29, 2005 | 03:19 PM
bign1976's Avatar
bign1976
You know, there is a bracket that is suppposed to be used when you have a front license plate. Then you don't have to drill your bumper. I had one in my 01 ram, and my 05 ram.... never used because we don't have front plates.
Old Jul 29, 2005 | 05:25 PM
Megashifter's Avatar
Megashifter
Here's a tip... (my own idea). Get a pair of door hinges from Home Depot. Mount the plate to an aluminum plate of the same size (for strength) and add a plate frame. Mount the plate assy to the door hinges and then mount the hinges to the underside of the truck... around the rad pan shielding.
The tag should be able to swing backward when you hit somethin'. You can't see it... but there is a front tag on my R/T... mounted in this manner and tied back (cause it'll hit the ground otherwise) 'Had it this way for near 4 1/2 years.
Old Jul 30, 2005 | 12:27 AM
horatio102's Avatar
horatio102
Why bother installing it? In WA the law states it must be mounted vertically between X and Y inches from the ground, so you're no better off having it on hinges.
Not that it really matters, in my 5.0 the front plate has been securely wedged between the passenger seat and center console for the past 2 years.
Old Jul 30, 2005 | 02:42 PM
Tani1500's Avatar
Tani1500
you have to have it in jersey
