1st-2nd Clunk ?
Old Oct 30, 2011 | 06:11 PM
ToastKing30's Avatar
ToastKing30
Default 1st-2nd Clunk ?
I have question, When im pulling out slow there is a loud clunk somewhere while my auto transmission shifts from 1st to 2nd gear. Is this my transmission taking a dump on me or could it be a adjusted or something else I might have overlooked? It only does it under low throttle if im giving it more gas it wont clunk between gears any
Also I just took a look under my truck and Im leaking fluid from one of the seals from the transfer case, could low fluid in the transfer case cause this or should I worry more about my transmission kicking the bucket soon?
Old Oct 30, 2011 | 08:07 PM
ToastKing30
Could the output speed sensor contribute to this even though my speedo is working properly and I have no CEL?
Old Oct 30, 2011 | 08:12 PM
chadhager03's Avatar
chadhager03
It could be transfercase, if you have a 4x4. Google transfer case saver, it's like $40. It could be u-joints or just normal driveshaft slop (unless it's real loud) and you're just noticing it from first to second Because you're going slower, which means quiter, so you can hear it better
Old Oct 30, 2011 | 08:23 PM
ToastKing30
What does the transfer case saver do, Would it keep it from clunking or what?
Old Oct 30, 2011 | 09:17 PM
UnregisteredUser's Avatar
UnregisteredUser
It replaces the output shaft snap ring, which is a failure prone part. It gets ugly fast when that snap ring pukes. You can get the Transfer Case Saver here.
Old Oct 30, 2011 | 09:39 PM
ToastKing30
Allright sounds good I will have to look into getting one then. Anyone at all have any input on what could cause the clunk between 1st and 2nd anyone ever have the problem before?
Old Oct 30, 2011 | 09:52 PM
chadhager03
My truck did it then my transmission died two months later, but I fought in a mud hole Going back and forth for an hour lol
Old Oct 30, 2011 | 10:08 PM
gdstock's Avatar
gdstock
I think the input you got was pretty darn good. Start there. Also (believe it was mentioned also but not sure) check U Joints.
Do these things and post back the results. Ideas come from knowing what has been done, and what has helped or not helped.
