headers short or long tube
Old Nov 2, 2011 | 05:44 PM
biggreen2500's Avatar
biggreen2500
Default headers short or long tube
hey i just browseing ebay and found this pacesetter short headers that bolt up to the stock y pipe
now for a daily drive/ tow rig
would would be best shorty headers or long tube headers?
what are the pros and cons of each one?
http://www.ebay.com/itm/Pacesetter-H...item53e8115370
Old Nov 2, 2011 | 05:47 PM
Just changing the manifolds to headers really won't help much, gotta address the stock y-pipe, thats where the major restriction is. If you wanted to do shorties, and an off-road y, that would perk things up a bit. I think you would get more out of long-tubes, and duals, (or, a good custom y, and 3" single exhaust...)
Shorties and OR y have the advantage of being direct bolt-ons. Long tubes would require some exhaust fab work, but, would give more benefit. (the difference would prolly be less than 5 horsepower though.)
Old Nov 2, 2011 | 05:53 PM
biggreen2500
so for someone on a budget i could get the short headers now then once i have most funds i could just get a custom y pipe..
so what about the stock y pipe cause such a major restriction. i've looked at mine before and i've noticed that piping looks pretty small is that it?
Old Nov 2, 2011 | 05:57 PM
You have two, two inch pipes, that get squeezed together into one 2.5 inch pipe. (I think it's 2.5.....) Where the three come together, the two pipes from the manifolds are crimped down to fit into the other pipe..... not a good plan. Makes the outlets from those pipes MUCH smaller.
Given the choice, I would do the y-pipe first. (Jegs or Summit Off-Road Y-pipe.) They run around 130 or so. That would be the most bang for the buck in the exhaust. Keep in mind though, if you have emissions testing, it will fail. (no cat.)
Old Nov 2, 2011 | 06:07 PM
biggreen2500
my town doesn't have emissions and i already have a gutted out cat.... well i've seen this off road y pip but i can't find one they says its for a 2001 it seems like they all say 94-97
Old Nov 2, 2011 | 06:10 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
holy cow...how many times do you restate your knowledge HeyYou?
Old Nov 2, 2011 | 06:13 PM
biggreen2500
http://www.ebay.com/itm/PaceSetter-O...item4cfb35d4d8
i found this.... is this one to be used with long tube headers?
Old Nov 2, 2011 | 06:20 PM
They are out there.... just gotta dig. Also, search using the Ram 1500. Not the 2500. The exhaust is exactly the same, but, searches won't give you good results.
Old Nov 2, 2011 | 06:21 PM
Ugly1's Avatar
Ugly1
Another option for y pipes is the ~$20 Magnaflow universal y pipes. That's what I bought and my muffler shop didn't have any trouble splicing it in.
Edit: oops meant to say ~$30 not $20
Old Nov 2, 2011 | 06:23 PM
Ugly1's Avatar
Ugly1
Check his post count. HeyYou is a very patient man.
